F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > fuel tank size questions
Extreme Powerhouse
      10-16-2013, 09:18 AM   #1
carzaddict
158
Drives: 2015 Cadillac Escalade ESV
I know the car has a 15.8 gallon tank. My question is....does that include the reserve tank? or is the reserve tank an additional 1-2 gallons?
How big is the reserve tank?
When does the reserve tank kick in?
Thanks
2015i Cadillac Escalade ESV
      10-16-2013, 09:37 AM   #2
Avian
Avian's Avatar
South Africa
44
Drives: 2020 F44 BMW M235i Gran Coupe
I think that includes the reserve tank because when I go below 50km(31Miles) remaining it shows a message showing something to the effect of that I must fill up as I'm now using fuel reserve. Don't quote me word for word because I haven't gone that low in a long time but it was something like that.
      10-16-2013, 09:45 AM   #3
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Based on other BMW's the F30 should have less than 1 gallon in "reserve" once the car reads 0. I do not believe BMW discloses that # or it's simply based on a percentage of the primary tank. If I had to guess .8 of the 15.8 tank is reserve on empty. BMW's seem to be notoriously accurate with their needles. Compared to my previous Acura where I know there was at least 3 gallons left on E.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-16-2013, 09:46 AM   #4
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
There is no such thing as a separate "reserve" tank....
I believe the warning pops up when you have less than 2 gallons in the tank...after that you're on your own.
      10-16-2013, 11:05 AM   #5
Fille
Fille's Avatar
Sweden
13
Drives: 520d -15
Pretty sure there is a separate "zone" where the reserve fuel is located (same tank different location in it). I have a 320d (15.05 gallon tank) and i've driven till the car said i'd have 20-30 kms (it fluctuated a lot) left and then went to fuel up. The car only took in 14.34 gallons even with three clicks.
So I think my car has a like half a gallon reserve. Makes sense though if you think about it. It's like idiot proofing. Even though some dumbass would try to push it all the way to 0 kms left it would still be drivable...
I'm just a regular everyday normal guy.
      10-16-2013, 11:51 AM   #6
tdizzle
Drives: 2017 F80 ZCP
This was also my assumption. That there isn't a physical 'reserve' tank. It's merely the electronics going the extra mile (pun intended) to ensure you don't run out of gas. i.e., car reads 0 left but you have a splash left in the tank.
I could be wrong though. Seems like a physical reserve tank wouldn't be cost effective when there are all kinds of electronic gadgetry to tell you that you're about to run out (as if the fuel gauge isn't enough).
EDIT: Apparently the old M5s stated the size of the 'reserve', but I couldn't figure out if that was included in the total capacity or just to note when the warnings would go off. Ours just show total capacity making me think there isn't a physical reserve. The plot thickens.
      10-16-2013, 12:04 PM   #7
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25108
Drives: '22 Chalk Gray Porsche C2S
In the E9X cars, I could drive about 20 miles once the display read "0". I have yet to test the limits of the F30.
      10-16-2013, 01:24 PM   #8
btbossman
Drives: 2013 335xi M sport--2014 M6
I would say thats about right currently. I took a trip from dc to charlotte nc this summer, 405mi...spirited driving included, was on E for about the last 15-20mi...worked fine but I wouldn't push my luck any further
      10-17-2013, 02:42 AM   #9
Mobster1983
42
Drives: 2014 BMW 335i
Thanks
Lots of questions in this thread and no answer. I nominate the OP to be the test subject to confirm or deny the existence of "reserve fuel." Go drive until your car runs out of gas and dies. Fill her up and tell us how much gas she took.
      10-17-2013, 03:05 AM   #10
Avian
Avian's Avatar
South Africa
44
Nice!
      10-19-2013, 09:34 PM   #11
BXL4
Drives: 2015 328i Alpine White
If BMW specs their fuel tanks like their engine outputs, this could hold 18 gallons. I have a M-B ML320 that claims to have a 18.5 gallon tank but I have put over 20 gallons in it on a few occasions. That would be a lot of filler nozzle.
      10-20-2013, 04:37 AM   #12
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Here you can find a technical drawing of the gasoline tank.
http://www.f30post.com/forums/showthread.php?t=858575
See Chapter 3 on 02_F30 Powertrain.pdf
60 Liter flat. No reserve tank.
Reserve light will show up with about 1/6 left in the tank. Bordcomputer will adjust your "milage left until walking" depending on drinving conditions.
f30post
