2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum What would LSD actually mean on the 2-series?
      10-14-2013, 03:46 PM   #1
MegaMatt3
Bimmer Candidate
Drives: '16 M235i
Hi all,
With the new specs and photos that have come out the last couple days, there's been a lot of talk about the (seeming) lack of LSD standard. I believe some have speculated it could be an option.
I'm not a car guy, really. I follow car news on a daily basis, particularly the 2 series because I'm interested in getting one, but I really don't know much about under the hood.
I read most of the wiki on LSD, but that left me with more questions that answers. Would someone mind breaking down for me what kind of real benefit I could see with LSD? Better handling, better mpg? I'm inclined to trust the folks in this forum when they say it's good to have, but I kind of need to know more to feel comfortable paying extra if it's an option.
Thanks..
      10-14-2013, 04:17 PM   #2
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
If you don't know what it does, you don't need one.
It improves traction when putting heavy power in-curve, with bumps. With no LSD, all the power goes to the "lifted" wheel, and no power goes to the on-the-ground wheel, resulting in the lifted wheel spinning more and giving you none of the desired effects of power oversteer you were looking for. With the LSD, some of the power goes to the on-ground wheel, and less goes to the lifted wheel, so you have a more controlled delivery of power and you can still throttle steer the car even when it is unsettled on bumps.
      10-14-2013, 05:37 PM   #3
Ramos
Ramos's Avatar
Drives: G20 2020 M340
It's not only helping traction when one wheel is lifted or unsettled over a bump, it helps traction during any aggressive cornering where the outside tire has more weight transfer and more traction.
Having said that, you really do not need it unless you autocross and / or track your car regularly and are advanced enough to even notice the difference.
For street driving, the standard e-diff is more than sufficient
      10-15-2013, 03:01 AM   #4
ORIGIN M.
3160
Drives: ///M
^ I agree
However it transforms a car w it
      10-15-2013, 07:32 AM   #5
Rupes
Rupes's Avatar
Drives: F87 M2 (current), E90 330xi (w
I'm also somewhat new to the LSD discussion, but I'm curious if someone can explain the difference between an electric diff vs. a LSD on a BMW. A quick search on the internet reveals some interesting information on electric diffs on trucks and 4x4's, but what about on a BMW? Is this simply the traction control braking that occurs under hard cornering when sliding? If so, this sucks. I always disable the nanny's on a track because I find it intrusive. Can someone let me know if I'm confusing an electric diff with traction control or if these systems work together in some way?
      10-15-2013, 10:13 AM   #6
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
Electric diff uses traction control sensors and brakes to operate, but it is not the usual DTC system (that we all hate when having some fun). It limits its action to activating the brake on the "lifted" (I do not really mean off the ground by that, just the wheel that has no weight on it) wheel when it starts spinning much faster than the other wheel, in effect redirecting some of the force to the right wheel. It does not cut power or correct for off-axis movement of the car.
I'm not sure if it remains active when turning all the nannies off.
      10-16-2013, 07:50 PM   #7
TheAcAvenger
TheAcAvenger's Avatar
Drives: 2018 R35 GTR / 2007 E92 335i
It means I won't have to get one from Quaife
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
      10-16-2013, 10:19 PM   #8
M3_WC
1040
Drives: M3
Ha...nice.
BMWCCA parts discount ftw.
      10-18-2013, 08:30 AM   #9
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Here's what it means if you are like me an like to modify cars:
In my 2010 n54 335i, I added a tune, downpipes, intake, and a water/meth injection system and made 412/446 RWHP/TQ. I also had coils and larger wheels/tires running 275/30/19s in the rear.
With the added power, I couldn't get traction off-the-line and needed to feather the throttle starting in 2nd gear (with the 6 speed auto trans) to get a decent launch. Still, my 0-60 times as measured on my V-Box were between 4.2 and 4.5 seconds. Not bad but not good considering the power I was making.
So I picked up a Wavetrack LSD and it just transformed the car. I could do 0-60 in under 4 seconds ever time, even when it was damp/wet outside. My best time was 3.5 seconds and mostly was in the 3.7 to 3.8 second range doing nothing more than just flooring it from a dead stop in 2nd gear. No brake boosting and I didn't even need to warm up the tires.
Also, as other posters mentioned the performance on the track was much improved, particularly coming out of corners.
The LSD is a must have and I'm only considering ordering the M 235i with the M-Sport package (supposedly comes with the LSD according to Jason's 7-22-13 post).
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      10-18-2013, 08:47 AM   #10
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
Your 335 sounds like a beast!
In regard to the M sport package, will we even have that option on the M235? I ask because the M sport "stuff" seemed to came standard on the 135s that I have had...I would think that would be the case with the M235 as well, but I could be wrong.
As far as the LSD goes, it sounds like it will be a BMW performance part, not standard, at least that's the last that I heard.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      10-18-2013, 11:10 AM   #11
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
It's not an option in the M135i so don't think M sport will be an option here either... to me it's like the M sport package is standard on the M235i
      10-18-2013, 11:57 AM   #12
Longboarder
3431
Drives: 2016 BMW i8
My modded 335 was fun. But nothing like my M3
Here's the thread that confirmed the M235i with the optional M Sport Performance Kit will come with an LSD:
http://www.2addicts.com/forums/showthread.php?t=867904
See above.
a couple others
      10-18-2013, 12:13 PM   #13
pikcachu
pikcachu's Avatar
1399
See above.
I'm talking about the M sport package (M wheels, M steering wheel, bumper etc) not the M Performance kit....
M sport package will be standard on the M235...
You might be able to get the LSD with the M performance kit or even maybe individually as an M Performance part later in March it's been said
      10-18-2013, 12:39 PM   #14
Longboarder
3431
Drives: 2016 BMW i8
M Sport Package and M Performance Kit...I must have been not clearly read the terminology used. Reading comprehension fail on my part then.
Anyway this (M Performance Kit) will probably be a very expensive option unfortunately.
a couple others
      10-18-2013, 12:49 PM   #15
pikcachu
pikcachu's Avatar
1399
Here is a really cool explanation for the OP on how an LSD works
      10-18-2013, 02:29 PM   #16
dmboone25
dmboone25's Avatar
4972
2007 328i  [10.00]
Now THAT makes more sense--it will also come with a power bump, yes?
Can't wait to see the official specs...
      10-21-2013, 10:11 AM   #17
MegaMatt3
Bimmer Candidate
Drives: '16 M235i
Thanks all. I'm gathering LSD is important to the performance/track folks, but not relevant to those outside those circles. For better or worse, I think I'm on the outside. I care about performance and driving experience (I'm looking at the successor to the 1 series, after all), but I don't know enough to start modding. Maybe one day...
      10-21-2013, 06:14 PM   #18
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
yeah I considered whether to install an LSD into my new 135is and the general consensus is that you only really feel it on the track or in very aggressive driving; which I rarely do. A few people have suggested otherwise but it is a small minority from what I've read.
      10-25-2013, 07:41 AM   #19
beamercharles
Drives: beautiful BMW z3
hallucinations?
Tags
2-series, lsd, m235i, options
2addicts
