Can Cobb AP read engine vacuum?
10-14-2013, 09:04 AM | #1 |
28
Rep 488
Drives: 2008 335xi E90
Can the Cobb AP read actual vacuum in the engine? Any sensor in the intake manifold, or do I need to hook up a vacuum gauge like how the P3 is connected?
MHD Self-Tuned Scaled FlexFuel Map | M-Boost | N20 Tmap | Helix IC | Fuel-It Stage 2 LPFP | BMS DCI | BMS Thermostat Delete | CP-E Charge Pipe | Tial-Q BOV | Apex Arc-8 Hyper Silver | Michelin PSS | Cool Carbon Brake Pads R/T | SS Brakelines | ECS 2-Piece Rotors F/R | xHP Stage 3 | xDelete Sport | KW-V1 Coilovers | Turner Strut Brace | Lux Angel Eyes | CF Kidneys | Scoops
10-14-2013, 09:07 AM | #2 |
562
Rep 3,625
It reads vacuum when you are monitoring boost. Mine reads about -8.0 psi's at idle so you know it is reading vacuum.
10-14-2013, 09:11 AM | #3 |
Professional Coin Flipper
16
Rep 150
10-14-2013, 09:23 AM | #5 |
16
Rep 150
10-14-2013, 10:50 AM | #6 | |
3441
Rep 79,211
30FF codes would appear if you underboost for 3-4 seconds. Sometimes you are on the threshold of not throwing an underboost code in which the only solution would be to A) find the source of the leak and B) look at Wastegate duty cycles to see if they are elevated in logs. |
10-14-2013, 07:43 PM | #7 | |
28
Rep 488
I took another look at the Cobb. There is a MAP output (manifold air pressure ?) which reads a low of about 400 (units? Maybe millibars? Maybe mm Hg ?) idling, to about 1000 (units?) with low revving at about 2000 rpm (easy driving), to more than about 2000 (units?) WOT. Sudden off accelerator I can hear the diverter valves open and the MAP value goes down to a low of about 220. If in fact the units here are millibars or mm Hg absolute pressure, (14.7 psi = 1013 millibars = 760 mm Hg) then it makes sense that MAP is in fact the absolute pressure in the air manifold.
10-14-2013, 08:26 PM | #8 | |
562
Rep 3,625
10-15-2013, 01:42 PM | #9 |
28
Rep 488
I keep up to date on the AP firmware and AP manager. Last firmware update was about 6-8 weeks ago?
