Bottoming out in the snow
12-09-2005, 04:47 PM | #1 |
288
Rep 874
I've been rather pleasantly surprised today in my first real experience driving my car in the snow with Dunlop M3 DSST tires on 17" wheels. However, I thought it is worth posting a special thread to warn people about the low clearance of this setup (I have the sports package).
My initial strong confidence was seriously shaken after I basically bottomed out on a side street going up hill. It was really tough getting out because the right side of the car had good grip but, because of bottoming out, the left side wasn't totally on the ground. The car's back end would spin to the right and counter steering didn't do enough because of lack of contact. It was very tricky trying to prevent the back right side of the car from hitting the curb or a tree that was on the right. I kept backing up the street, staying on the left and going up with the car going up the hill at a 30 degree angle with a huge counter steer. In the end a plough came from the front and ploughed a large area that allowed me to finished the rest of the street. The rest of the way home, my car was basically ploughing the middle of the lane where the snow is high. No other sedan on the road was as low as mine. It was really weird to be scraping the snow for most of the way home!! I think one thing that makes bottoming out in this car especially bad is that it is basically sealed on the bottom with flat panels, making the car have a uniform flat surface on the bottom at the lowest possible depth clearance of the car instead of varying depths. This was the first time I ever get stuck in the snow and it didn't feel good.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
12-09-2005, 04:55 PM | #2 |
30
Rep 233
Drives: 2020 BMW X3 xDrive30i
so you're saying we need winter springs too
while i wasn't in enough snow to experience bottoming out, its good to know its a possibility in drifts and whatnot |
12-10-2005, 03:12 PM | #5 | |
21
Rep 1,002
No, not THAT kind of tierfreund!
12-10-2005, 03:23 PM | #6 |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
But can you just imagine the same situation with your stock 18's.
We havent had real good snow here for me to experience the same conditions you had. ZSP and non ZSP profile, is not much of a difference. Am I missing something here? maybe you should have just waited a little longer to get the snow plowed.
12-10-2005, 08:59 PM | #7 |
288
Rep 874
Unfortunately I couldn't have waited and other cars were able to go through (I saw their tracks, and they weren't big cars). Let's face it, the car with ZSP is low and it is a bit lower with 17's. Again, the car is generally very good in the snow, but one has to be careful about the low clearance. It is lower than most other sedans.
12-10-2005, 11:10 PM | #8 |
25
Rep 513
maybe you should've gotten an xi...
I'm quite skeptical about the 330i being "great" or "fine" in the snow with snow tires. But seeing how many of you are saying it, I started rethinking my choice to get an xi. Then again, I see this thread about getting stuck. Someone shed some light; I'm confused. |
12-10-2005, 11:32 PM | #9 |
288
Rep 874
I think there is no reason to be confused. If the snow is too deep for a car -- any car -- it can get stuck. Ground clearance is one more variable that needs to be taken into account when driving in the snow. This was the point of my thread.
I drove for 6 hours in the snow yesterday and had no problems except this one. It reminded me that I'm driving a low car and I need to adjust to that.
12-11-2005, 12:37 AM | #10 | |
25
Rep 513
12-11-2005, 07:13 AM | #11 | |
9
Rep 35
I live in Boston too and drove through the same snow you speak of. It was the first winter exeperience with new 325XI. From the way things handled, you would have thought it was summer. The way home took 1 hour, I passed all sort of cars stuck on the sides of the road, but the best part of the drive was when I passed a stuck plow (no joke)! The snow was was soft and powdery, not icy. No fear of hurting the car. Came back home at 6pm to find about 8-12 inches in our driveway. We have a long driveway, about 200 feet to the garage. I took out a shovel to break through the 2ft of plow buildup at the entrance ... then gave it some gas and drove right through the white stuff like it wasn't there :rocks: The 325xi is better in the snow, higher ground clearance, and that AWD thingy |
12-11-2005, 08:29 AM | #12 |
418
Rep 12,276
Yep... once any vehicle bottoms out in snow you're stuck. I had an Isuzu Trooper get stuck once because too much snow was packed under it... until we have hovercraft this will be simple physics. The E90 is certainly a low car and will be suceptible to this.
I think it is bad luck to be superstitious |
12-11-2005, 09:57 AM | #13 |
288
Rep 874
Yes, I'm sure xi is better in very deep snow, as it will raise the maximum snow depth you can go through to a degree. Also, if you look at the BMW website, they list the i and xi as having the same ground clearance (at least I couldn't fine any difference listed). In my case, I have the Sports Package which is known to be lower than the standard car. Have to get used to having a "sports" car that is low to the ground.
12-11-2005, 12:00 PM | #14 |
12
Rep 942
The car is lowered a mere 0.8 inches...
This is a luxury sport sedan, that sort of trade-off is to be expected (On the xi as well, it will go a bit further but forget about it if you have 1 foot of snow). Maybe that's a reason why people still buy SUVs despite the price at the pump...! |
12-12-2005, 06:49 AM | #15 | |
288
Rep 874
Others get them because they are... well... crazy
