10-08-2013, 05:02 PM | #1 |
124
Rep 1,840
Drives: '14 M5 CP Dinan Stage 2
Heads Up Display
The heads up is to low for me. I am wanting closer to my field of vision when driving. As it is now i have to look down and its really not much different that looking at the speedo. I have it adjusted as high as it will go in the setting and i even tried to lower my seat (helped a bit). I am only 5'9.
Any advice? Can this be coded higher or it a physical limitation? Anyone else have this problem? Thanks, JS |
10-08-2013, 09:31 PM | #2 |
26
Rep 365
I'm pretty sure the optics limit the range. Have not run into this issue, maybe somebody else?
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
10-08-2013, 09:57 PM | #3 | |
Commander
14
Rep 147
Drives: '14 M5 CP & '14 X5 50i
I'm 6' and it works great for me. Some thoughts:
10-09-2013, 02:34 AM | #4 |
124
Rep 1,840
Thanks all above have been done. So no luck don't know why mine is so low. Will have to get it looked at when the car is back state side.
10-10-2013, 08:53 PM | #5 |
127
Rep 1,622
The HUD height adjustment offers a huge range. I can't imagine it being too low where you can't see it while set at maximum height.
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
