M5POST
Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Sponsors Classifieds
      10-03-2013, 06:37 PM   #1
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
CHALLENGE - F10 M5 Stainless Steel Brake Line Kit - Made in the USA
This full stainless steel line kit for the M5 replaces all your flexible brake lines on your performance BMW. We retained the stock line configurations and mounting points for an OEM quality fit and finish.
Challenge uses high quality extruded PTFE hose with a stainless steel braided outer. Each line set has a clear coating protecting it from any of the elements. Stainless steel braided brake lines will not expand or contract under braking. This results in a firm brake pedal that is easier to modulate without locking the brakes gets rid of any "squishy" vague brake feel
All parts and components are DOT approved. Made in USA and includes lifetime warranty!
UPDATE:
All new line kits now have our special line material with the challenge logo along it to ensure authenticity and quality
MSRP: $125.00 USD Free 2-3 day shipping within the USA
*** Please contact us with any product questions, quote requests or information for your nearest authorized Challenge dealer ***
      10-23-2013, 07:17 PM   #2
GTM_Challenge
Thanks for the order!
      11-15-2013, 12:09 PM   #3
GTM_Challenge
More brake line kits good in stock for most all M model cars
      11-26-2013, 12:23 PM   #4
GTM_Challenge
More kits for M5 will be ready by end of day tomorrow.
      12-04-2013, 10:28 AM   #5
GTM_Challenge
Plenty of M5 brake line kits back in stock!
      12-08-2013, 04:38 PM   #6
ppatel223
31
Drives: F10 I3.0
Is the upgrade compatible with non M 5ers?
      12-08-2013, 08:21 PM   #7
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
Does this kit have 6 lines like the e9xm3 ...or just the 4 pictured?
      12-09-2013, 07:44 AM   #8
MCM5
MCM5's Avatar
13
Drives: MCB F10 M5
Would like to know too.
      12-09-2013, 08:26 AM   #9
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
Will these work on the Carbon Ceramic brakes? Any benefit, i don't know what they have for stock brake lines may already be braided?
Thanks,
JS
      12-09-2013, 09:20 AM   #10
GTM_Challenge
We do have applications for non M 5 series as well. I will shoot you a PM to get your model spec.
      12-09-2013, 09:22 AM   #11
GTM_Challenge
The M5 kit is a 4 line kit. The picture shown is the actual kit for F10 M5
      12-09-2013, 09:24 AM   #12
GTM_Challenge
Thanks,
JS
I'll confirm this for you. It should be the same caliper on both brake model cars but will check with BMW. OEM lines are all rubber type lines.
Thank you.
      12-10-2013, 03:54 PM   #13
GTM_Challenge
Confirmed: Carbon brakes and steel brakes all use the same brake line kit.
      12-20-2013, 12:13 PM   #14
GTM_Challenge
F10 M5 kits good in stock
      01-04-2014, 09:42 PM   #15
Spinny02
Spinny02's Avatar
Thanks for the kit! The lines fit great. I am very happy with quality and the brake feel. The shop used 1.5 ltrs of Castrol SRF. One ltr would have worked but they did a good flush of the system.
      01-04-2014, 09:46 PM   #16
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
Awesome. Do you notice the difference or is it subtle?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      01-04-2014, 09:57 PM   #17
Spinny02
Spinny02's Avatar
Different feel for sure. The peddle has to be depressed more before the brakes grab and then it's one consistent motion to stop. It is a noticeable improvement. Now have to retrain my muscle memory from years of expanding brake lines.
      01-08-2014, 04:39 PM   #18
GTM_Challenge
Thanks for the feedback on the lines. Glad they did the job for ya!
      01-09-2014, 01:55 PM   #19
ddrreeww
Hong Kong
Drives: F10M5 Monte Carlo Blue
do u hav actual figures that show how much would be the difference between standard F10M5 brake lines VS your stainless till brake lines. i mean, u got to hav some test result reflecting the actual performance under certain braking conditions?? or is it a "personal feel" factor more?
sorry if my Qs may seem too technical but i think i got to know this data before upgrading to anything especially when it is to Brake system.
many thx.
Or if any knowledgeable users can help to answer this
      01-09-2014, 05:12 PM   #20
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
many thx.
There is not much data out there to support any actual improvement.
But brake systems are hydraulic fluid under pressure. So using reinforced stainless steel lines helps the fluid flow without expanding or flexing the brake lines in the process. However, this really is only felt during extreme hard braking.
There is no safety issue as these lines are more robust then the OE rubber ones.
As long as they are installed properly.
The best proof of their actual functionality is Professional and Amatuer racing series.
All of them change the rubber lines to stainless steel brake lines.
      01-10-2014, 07:37 PM   #21
GTM_Challenge
Thanks for chiming in. You pretty much said about everything I would have mentioned.
The greatest benefit is usually in pedal feel and modulation under heavy pressure like when on track or driving aggressively. They also hold up to heat much better than they typical rubber brake line.
      01-10-2014, 07:52 PM   #22
Mcar2008
30
Drives: F12 M6, G30 540i
Do you have these lines for F01?
