Smog
09-27-2013, 11:21 AM | #2 | |
NorthTexasBimmerClub
38
Rep 97
Drives: 2007 e90 335i
09-27-2013, 12:40 PM | #3 |
Rep 39
Everything is stock, the only mod I have is the jb4. I didn't pass smog and don't know why. I did change the map to 0 which is off if I'm correct. Here's what the paper said: "This vehicle did not pass the OBD System Check because its OBD system was not ready to test". Can someone help me out?
09-27-2013, 12:56 PM | #4 |
39
Rep 656
You need to drive your car in Map 0 with autoclear off. The car needs to heat cycle 4-5 times and be driven around 80-100 miles so that the O2 sensors will be tested and ready before re-smog-ing.
09-27-2013, 02:01 PM | #5 |
Rep 39
Oh I see. So from now until I get my car re-smog again, I should be driving it in Map 0 with autoclear off for 80-100 miles? This should fix the problem and let me pass smog?
09-27-2013, 03:37 PM | #6 |
292
Rep 2,898
09-27-2013, 05:37 PM | #7 |
39
Rep 656
"drive cycles" meaning car needs to warm up completely then cool down and repeat. If you drive for a week with the car then go test everything will be good. No autoclear as I stated previously.
09-27-2013, 06:26 PM | #8 |
Rep 39
12-17-2013, 11:22 AM | #11 |
39
Rep 656
If you are on the stock exhaust, put a o2 sensor fix in and you should be able to pass the sniffer. If they dont have a sniffer where you are testing then you will be fine. Otherwise, pay a guy to pass it or swap your dp's out for a few days.
12-17-2013, 12:26 PM | #12 | |
Rep 92
When I owned an RX-8 I was catless and probably 2-3 days before I changed over to stock cat and stock map and reset the DTC for the drive cycles to be completed in time for the smog. Also depending on who you know, or don't know.. I'd rather swap cat on than pay somebody, I was quoted like 200 bucks.. Swap didn't take 200bucks worth of labor, so definitely worth just changing over. Last edited by IronMask; 12-17-2013 at 12:31 PM.. |
12-17-2013, 12:29 PM | #13 |
146
Rep 1,922
Drives: E90 335i, E70 X5
nope, we are in the best State of the emission king, that's why i stayed away from DP and it's been a hassle either find someone to smog it or swap out DP. unless all the stations start doing the OBDII test soon, then DP wouldn't be a problem
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
12-17-2013, 12:55 PM | #14 | |
39
Rep 656
12-18-2013, 11:28 PM | #15 |
18
Rep 109
I would definitely swap the stock one back on but damn...I don't have the time to do that and it's like 3-4 hour job. I'll just do the JB4 and be done with it....
12-18-2013, 11:41 PM | #16 |
Rep 48
Just did smog last week, down pipes and jb4, map 0, 40% E85, Downpipe fix, and had to get her SUPER hot, like 45 minutes of canyon racing, failed first time, had to heat it up so more.
Toyota Camry-Still Alive**Lexus ES300- RIP**Toyota Supra- RIP**Nissan Maxima-RIP**Infiniti G35-RIP**Audi S4-RIP**BMW 335i-Still Alive
01-02-2014, 10:57 PM | #17 | |
Rep 57
Can you tell me how you drove the car prior to taking it in?
| 08' E90 335i | ZSP | ZPP | iDrive | BMW Performance Grilles | M3 Rep Front Bumper | LED Angel Eyes | Ebay Rear Spoiler | BMW Performance E-brake | BMW Performance Shift Knob/Boot
01-02-2014, 11:10 PM | #18 | |
Rep 57
This has been frustrating me. After I failed the first time, the smog tech told me I just needed to put a few miles on it and re-test. Have driven it every day for 2 weeks and put several hundred miles on it, but still failed a second time.
01-02-2014, 11:38 PM | #19 | |
Rep 48
01-03-2014, 11:58 AM | #20 | |
Rep 39
01-03-2014, 12:20 PM | #21 | |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
So, FWIW I think you should just "bite the bullet" and take the car to the dealer or a qualified BMW service shop to diagnose and fix the problem. Just my 2 cents. Good luck! |
01-03-2014, 11:15 PM | #22 |
Rep 57
Update: Got it to pass. Took it to the dealership to have the checked it out, turns it was a reading from the post cat O2 sensor due to a tiny exhaust leak. Just needed to tighten the exhaust and reset the bank one sensor. Took it right from the dealer to the smog shop and it passed with flying colors. Just an FYI if this happens to anyone that's stock.
Oh and from what the dealership told me, there's apparently no charge in CA for emission-related work. I assume this is based off of the model year, any modifications, etc., but I paid nothing at the dealership.
