Does your 335i auto goes into 1st gear when stop
09-24-2013, 05:15 AM | #1 |
23
Rep 224
Hi all,
Just wanna know if your 335i auto shift down to 1st gear when the car stop using the manual mode. Mine does not.....it stays at 2nd gear. Any clues?
2009 E90 335i / JB4 G5 ISO / M3 front sway bar / AFE DCI / Air Scoop / BC-BR Coilover /
09-24-2013, 08:56 AM | #2 |
171
Rep 2,682
It's normal for the 6 speed ZF auto to stay in 2nd gear whilst in normal drive mode. Most likely it's for efficiency.
If you go into DS mode then it will drop down into 1st gear when at a standstill.
09-24-2013, 08:56 AM | #3 |
On the hunt for PSI
41
Rep 778
That's normal if you are in "D" first is only used for hard off the line accelerating, the engines in most of the E9X's have sufficient torque to pull away in second gear, delivering a nice "smooth" of the line experience
2016 Alfa Romeo Guilia Quadrifoglio - Metallic White |
