2010 2011 BMW 5 Series Forum F10 Video: V1 Hardwire DIY Install F10 5 |
09-20-2013, 06:58 PM | #1 |
1579
Rep 2,406
Drives: E30 M3 Cecotto, F85, G05, G07,
Hi guys,
I just posted a video here that shows how to hardwire (using the V1 hardwire kit) the radar detector in an F10 M5, should be the same for a non-M. I used green wire with the brown stripe on it to tap into. It was hard to access the ground bolt, but with a swivel accessory it is possible. I referenced this guide for help as well. - http://www.bimmerfest.com/forums/sho...d.php?t=515517 Thanks to William for letting me use his car.
01-29-2017, 05:31 AM | #4 |
1579
Rep 2,406
Make sure you are doing the ground wire correctly. The screw we use has a coating on it.
01-29-2017, 02:37 PM | #5 | |
4440
Rep 5,332
I just gave up and am now running the wiring like I did in our '12 535... Down the "A" pillar and into the fuse box. |
03-07-2020, 11:59 AM | #6 |
712
Rep 538
2020 update: just completed this for my 2016 535; I had to do just like in the video, and put a half washer on top of the ground wire and the grounding screw in order for their to be a full connection.
For the wire giving power, in the video he instructs to use the green/brown wire. This DID NOT work for me at all. I ended up using the thicker red/brown wire, and BOOM, my Valentine started up no problem.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
cncmastr1579.00 |
Tags |
diy, hardwire, install, valentine one v1 radar detector |
