09-13-2013, 12:44 AM | #1 |
131
Rep 264
It's started
Hope that this isn't the start of a tale of woe. I am 900 miles into a trip round Spain and have a 'chassis' problem warning on the screen with the message 'Drive moderately' and consult Service (or something similar). It occurred after switching into Sport mode.
Seems to be running as normal so will try and find a dealer today. 1000 miles to go so I am a bit wary. |
09-14-2013, 08:05 AM | #2 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
How many miles do you have on the car?
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
09-15-2013, 09:21 AM | #4 |
Pygocentrus Piraya
927
Rep 1,008
Drives: 2021 BMW X3MC
Did you do a proper break-in on the engine? Go over 4800 rpms?
kozzi
2021 BMW X3MC Donington Grey Metallic / Sakhir Orange & Black Extended Merino Leather / Aluminum Carbon Structure |
09-15-2013, 05:10 PM | #5 | |
27
Rep 148
MrFargo13
Mine: 2014 X3 35i M-Sport VR on Black w/wave wood trim, Tech, DHP, DAP w/RR Top View Cam, Premium Sound, Prem Pkg, Cold Weather. The Wife's: 2011 328i Deep Sea Blue Metallic Navigation Premium Pkg Sports Pkg Xenon Heated Seats Folddown Rear Seats BMW Apps |
09-16-2013, 07:10 AM | #6 |
Pygocentrus Piraya
927
Rep 1,008
^not go over
kozzi
09-16-2013, 01:11 PM | #7 |
29
Rep 131
My dashboard lit up like mission control with a few various errors including chassis stabilization/drivetrain/brake warnings once as I was coming to a stop.
Everything went away with a restart. I figure the cause was a low battery, since I had started using ASS again not too long before it happened (and I normally only take short trips). Hopefully this is the same for you, and there's no bigger issues... although if you're in the midst of a road trip, there should be plenty of charge. Wouldn't hurt to run without auto-start-stop for a little while and see if it helps the situation at all. |
09-16-2013, 03:23 PM | #8 |
131
Rep 264
Thanks for the thoughts. My stop / start has been converted to 'Last user mode' so it is not in action at all.
The fault has not shown at all today and is not in the 'log' either. However - I am sure it will be back. |
