09-09-2013, 12:41 AM | #1 |
35
Rep 135
Tyre Pressures
I took my 335xd for a fast drive across a familiar fast road and I felt the car didn't feel quite right so the following day I checked my tyre pressures and found the fronts were over inflated by 3 psi and the rears by 5 psi and this has definitely helped the ride and handling.
So I suggest that you all check your pressures as it seems not all dealers do! |
09-09-2013, 02:58 AM | #2 | |
6659
Rep 15,858
Obviously a good idea to check pressures, but tyre pressure is a range not a fixed pressure. Most BMW models will have a range of about 0.5bar across the load carried and that is about 7.25psi variation when cold. Many drivers will run with a few extra psi than lowest figure, when driving hard and at speed anyway, and/or for a balanced wear and road feel. I run my pressures about midway, (from door plate figures) that's about 3.5psi up on the lowest end of the range, also very sensitive to ambient temperature on the setting pressure, even when cold. There can be a couple of psi difference across our typical day, 10C vs. 20C. HighlandPete Last edited by HighlandPete; 09-09-2013 at 03:04 AM.. |
09-09-2013, 04:26 AM | #3 | |
35
Rep 135
My son races in Ginetta Junior so I know how important tyre pressures on performance. |
09-09-2013, 04:34 AM | #4 | |
6659
Rep 15,858
Are you checking with a recently calibrated pressure gauge, time of day and ambient temperature exactly the same as BMW? And what is the absolute pressure the BMW garage would use? Just food for thought. HighlandPete |
09-09-2013, 04:53 AM | #5 | |
35
Rep 135
09-09-2013, 05:00 AM | #6 |
1854
Rep 3,983
Are you on P Zeros Ian?
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
09-09-2013, 01:09 PM | #8 | |
67
Rep 650
