09-05-2013, 11:00 AM | #1 |
Rep 1
Cargo capacity?
The information I'm finding online regarding cargo space on the 2014 X5 says 23.9 ft3 up to 66ft3 with 2nd row folded. However, the 2013 model information shows 35.8-75.2 ft3 cargo space. Yet the 2014 is supposed to be 7% roomier. Can anyone clarify this?
Also, any details on if the 3rd row seating is any better? Thanks! |
09-10-2013, 10:13 AM | #2 | |
Rep 37
09-10-2013, 10:48 AM | #3 |
40
Rep 361
Drives: E70 X5 35d
I'm not sure how it could be bigger as it is nearly identical. They may have changed the way that they measure it, as apparently there is no standard that the manufacturers use.
Compare the 2011 and 2014 rear cargo areas in the attached images. Google "201x BMW X5 rear cargo" for lots of images that show that the F15 will likely be able to share trim bits, accessories, etc. with the E70. |
09-10-2013, 10:57 AM | #4 |
1977
Rep 4,220
As an aside, I'm surprised the ivory nappa leather package uses ivory carpet in the cargo hold. Seems like that's just asking for trouble.
09-10-2013, 11:00 AM | #5 |
Rep 37
09-10-2013, 02:28 PM | #6 | |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
Your numbers are wrong P.S. If 23.9 is tiny for you, you are on the wrong forum and car make |
12-15-2013, 07:11 PM | #7 |
10
Rep 174
Bump. Has anyone ever found the correct numbers? I find the 22.9 cu. ft. (seats up) and 66 (seats down) (http://www.cars.com/bmw/x5/2014/specifications/) hard to believe when the '13 is rated at 35.8 (seats up) and 75.2 (seats down) (http://www.cars.com/bmw/x5/2013/specifications/).
For comparison: ML350: 38.2/80.3 (http://www.cars.com/mercedes-benz/m-...pecifications/) X6: 25.6/59.7 (http://www.cars.com/bmw/x6/2014/specifications/) Q5: 29.1/57.3 (http://www.cars.com/audi/q5/2014/specifications/) |
12-15-2013, 08:18 PM | #8 | |
547
Rep 3,307
12-15-2013, 09:18 PM | #9 |
163
Rep 533
Not sure about the cargo capacity but I moved the cargo liner from my 2011 X5 to my 2014 X5 and it fitted perfectly. Thus, at least on the floor measures they look identical.
