09-02-2013, 08:23 PM | #1 |
417
Rep 809
130i sucking gas like a sponge, please help!
Could someone suggest any reasons why my 2007 130i fuel consumption is so high? I'm not kidding, I'm getting 20kms (12.4miles) per gallon!😩
The car has no noticeable problems, no hesitation, not lazy, no acceleration issues, no weird sounds What could it be? Thanks for helping me out!
Proud BMW owner
E87 130i — E90 LCI 320d — F22 M235i — F15 X5 30d F30 LCI 320i MSport — G05 X5 30d MSport —— —— —— —— —— —— —— —— —— —— —— —— |
09-03-2013, 03:00 AM | #3 |
European Editor
10511
Rep 22,992
is that US gallon or Imperial gallon?
Auto or Manual? City driving or highway? I would pull a sparkplug out and have a look. Also have you checked for any codes? Sometimes your engine will throw a code but not turn on an engine check light. I would also look at your O2 sensors and the Lambda values with the engine running. That will tell you whats going on. You could also have a simple vacuum leak and the engine will dump in more fuel to compensate for it. You could spray some NON-flamable brakekleener around the intake with the engine running to see where a vacuum leak is.
09-03-2013, 08:54 AM | #4 |
417
Rep 809
Thank you all for your responses. Mine is automatic transmission. It is basically city driving with medium to heavy traffic.
I will check the air sensor and also for error codes. Could this be also related to the fuel filter? I will also try to do the leak check
Proud BMW owner
09-03-2013, 08:58 AM | #5 | |
Resident Tamed Racing Driver
292
Rep 4,697
http://www.1addicts.com/forums/showthread.php?t=809599 the fix... http://www.1addicts.com/forums/showp...9&postcount=66
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
09-03-2013, 08:28 PM | #6 | ||
417
Rep 809
I really appreciate your guidance bro and everybody else too. (y)
Proud BMW owner
09-03-2013, 11:33 PM | #7 |
198
Rep 2,239
The flash only writes over your current DME tune. You need BMW to update your car/transmission modules to fix the issue assuming its the same problem as the other person had. You're tuner can put another tune on after they update your DME as it will be erased after it comes back from the dealer, they are usually happy to help.
08 e93 335i MT
09-04-2013, 01:43 AM | #8 | |
European Editor
10511
Rep 22,992
09-04-2013, 06:57 PM | #9 | |
417
Rep 809
Cheers to all!
Proud BMW owner
09-04-2013, 09:47 PM | #10 |
292
Rep 4,697
Here's hoping it sorts you out.
