09-01-2013, 10:11 PM | #1 |
13
Rep 173
iPod "classic" problems with NBT
I've got an 80GB iPod "classic", and by "classic" I mean that it predates the branding of the actual "iPod classic" and about seven times out of ten when I fire her up iDrive (4.2 in a new 2014 NBT F30) can't see it at all. The iPod appears to function perfectly though and works for every other usage (including other cars). I've tried different cables and can't seem to find the culprit. Sometimes if I reboot the iPod while the car is running it will see it, other times it will not. iDrive has no problem seeing various types of flash media I have inserted.
Anyone experience anything like this? |
09-01-2013, 11:39 PM | #2 | |
149
Rep 1,135
Additionally, depending on where you live, an iPod Classic will only last about a year before the extreme temperature swings of boiling heat and frigid cold found in a car cockpit make the fragile physical drive slowly wear itself out. Sell your Classic on Craigslist, use the cash towards a beater iPod Touch, and move on before your Classic is nuked and worthless. |
09-02-2013, 01:35 AM | #3 | ||
13
Rep 173
Sure, it might fail spontaneously in the next year, because hard drives do that sometimes, but it's not acting like it's on it's "last legs" at all -- and I know the symptoms of a drive that is likely about to fail. Quote:
But ... you say this is a known issue. Do you have any links with more info on it? |
09-02-2013, 12:47 PM | #4 |
13
Rep 173
I think, or rather I hope, that I have found the problem.
*wood knocking ensues* While researching this I started to notice a pattern of certain people with the apparently identical issue (hard to tell sometimes because people often don't reveal sufficient info) all having "Replay All" turned on in the iPod. These cases are mixed in with all sorts of other reports which may or may not be related (locking up sometimes during playback, "disconnecting" randomly, etc). The problem I'm talking about is very specific, the iPod only has an issue when you first start the car -- once you get it to "talk" to iDrive it'll be fine until the HU powers down. So ... I checked the iPod, and sure enough, "Replay All" was turned on. I turned it off, plugged it in and it rapidly appeared in the iDrive menu. I've tested at various intervals and situations a good 8-10 times now and it has worked every time. Time will tell ... |
09-02-2013, 09:13 PM | #5 |
149
Rep 1,135
You move the genres that don't change (Classical, Jazz, etc.) to the hard drive in iDrive, load 'em into the glove box USB.
That opens up the space for a smaller iPod Touch flash drive to handle the genres that do change often and that you mix/match for Playlists (Rock, Classic Rock, Techno, Alt, etc.) |
09-03-2013, 05:17 PM | #7 | |
13
Rep 173
So far (after turning off "Replay All") it's been mostly okay. Sometimes there is a bit of a delay when first starting the car before it can see the iPod, but no more than a minute or two. Does your iDrive "see" your Classic immediately or ...? |
09-04-2013, 11:06 AM | #8 |
159
Rep 261
Drives: 2016 750i xDrive
So the current generation classics don't have the same problem as the older classics? My Gen 2. 160gb crashes constantly.
2019 X3 M40i Phytonic Blue/Oyster
Past BMWs: 2016 750i xDrive 2013 335i Sedan Sport Line, 2005 645Ci Coupe 6MT, 2001 M5, 2001 540i 6MT, 2001 M Roadster |
09-04-2013, 02:38 PM | #9 |
13
Rep 173
That's actually not the problem i'm having (although it certainly is a problem). My older "classic" is rock solid in terms of just running.
09-04-2013, 04:30 PM | #10 |
Rep 84
09-06-2013, 01:50 PM | #11 |
159
Rep 261
Ok, thanks for the clarification.
09-06-2013, 02:17 PM | #12 | |
Rep 207
09-06-2013, 02:18 PM | #13 |
Rep 207
Mine crashes (freezes) every once in a while but once I restart it there isn't a problem. It did it more in my vette than the 335. So far it's been pretty solid in the bmw.
09-06-2013, 05:14 PM | #14 | |
13
Rep 173
Now if only you could playback video with an iPod like you can with usb mass storage (+ coding). |
09-07-2013, 04:09 PM | #15 |
452
Rep 2,148
Drives: F87 M2 BSM MT
I have a 160GB iPod classic that i bought for the car in May 2012. Not sure what generation that is but mine crashes about once a month. A simple reboot and hitting play on iPod resolves the issue.
I would love to find a better replacement in terms of size and functionality. like itunes playlist, album art and video
09-08-2013, 05:56 AM | #16 |
Rep 88
Why not use a USB stick?
Works perfectly and there is no limit as to what size can be used. Leave it connected, plays all files, videos.... And it even fits in youre wallet. And the biggest.... NO DAMN CABLE!!! |
09-08-2013, 12:24 PM | #17 |
452
Rep 2,148
Does it show album art?
09-09-2013, 07:02 AM | #19 |
159
Rep 261
Do you have an iTunes library saved to it or just the media files themselves?
09-09-2013, 08:15 AM | #21 |
159
Rep 261
Out of curiosity, how many files do you have on your USB drive? The reason I ask is that, in past vehicles (non-BMW), there was a max number of files it would read, something like 5000 or so IIRC, so having a high capacity usb drive was useless. So, I'd like to be certain it will read as many files as I load up.
