08-27-2013, 11:34 PM | #1 |
179
Rep 1,044
Moving from F30 18" OEM wheels to 19" wheels
As per tirerack when you change wheels/tires the overall diameter should not change by more than +/- 1% , preferably +/- 0.5%
Now the 18" OEM wheels with 225/45 tires setup will have an overall diameter of 21.98" while the 19" OEM wheels with 225/40 tires will have a diameter of 22.51". That is more than half an inch diameter difference between the 18" setup and the 19" setup which actually happens to be a whopping 2.5% difference. Is anyone is aware whether the cars that come with 19" from factory are coded differently than those with 18"? If you simply throw in a 19" setup on a car with existing 18" setup won't the odometer be off (I mean for every 100 miles you drive your odo will register 2.5 extra miles!!) ? Also won't that throw off the traction control system? There are so many of you guys who have moved from 18" to 19" - have you'll given this a thought? |
08-28-2013, 02:09 PM | #3 | |
179
Rep 1,044
08-28-2013, 02:45 PM | #4 | |
1571
Rep 29,202
The 225/45/18 diameter is 26", and the 225/40/19 diameter is 26.1" That's a 0.4% difference.
08-28-2013, 02:45 PM | #5 |
101
Rep 1,237
Your overal diameters are impossible. For 225/45/18, the diameter should be close to 25.9 inches. And for 225/40/19, it should be close to 26.1 inches.
21.98 inch total diameter on an 18 inch wheel would mean that the tire side-wall would be only 1 1/2 inch thick... that'd be like a 20 or 25 series tire. |
08-28-2013, 03:15 PM | #6 |
15
Rep 606
I made that very change a few months ago. Went from 18 inch sportline wheels with 225 square set up to BMW oem 403m 19 inch staggered wheels. There is no difference in my odo at all.
08-28-2013, 05:50 PM | #7 |
Güten Täg
12
Rep 161
You will be fine. You could also go with 245/35/19 which would be 25.86" vs 225/45/18 which is 25.91"
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone |
08-28-2013, 06:06 PM | #8 | |||
179
Rep 1,044
You guys are right. I forgot to add the thickness of the side wall twice Quote:
That is an interesting point. Never thought of going wider on the front with 245/35. But I'm a bit wary that may cause rubbing with the lowered M-Perf suspension. Actually the 225/40 is not even available for the Micehlin Pilot A/S 3 so if I have to go with that tire, I will either need to move up to 245 or go with 18" instead of 19". |
08-30-2013, 08:48 AM | #9 |
1125
Rep 2,564
Your math is wrong. 225/45/18 is:
45% of 225 for EACH side of the wheel. So, 100 mm x 2 = 7.97". Plus the 18" wheel is 25.97" For the 225/40/19: 40% of 225 is 90 mm each side of the wheel. So, 2 x 90 mm = 7.08". That plus the 19" wheel is 26.08". |
09-08-2013, 11:33 AM | #10 |
Rep 207
