2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions ___DIY - Heat Shield For BMS Intake - 535i
      08-24-2013, 05:12 PM   #1
tvd75
tvd75's Avatar
Drives: 2011 550ix AW
Just to update that there was no test done before or after installing the barrier to see if there was any air restriction which may increase/decrease performance. Also, note that there is no guarantee that this DIY will keep heat and dirt away from the air filter. Please use this as a form of research and use it to your own discretion.
-sheet metal 26 gauge 12"x24"
-10" metal cutting snips
-3M tape
-high temp spray paint
-rubber tube seal along the top (not shown)
The shield was cut from a single 12x24 sheet metal into two separate pieces, parts A is outline in RED and B in GREEN (see pic).
The overall size of the shield is 10.25"x11" with the height of 3.75" in the back tapering down to 2.5" in front.
Part A is taped to part B with 3M tape (test fit first). I made the shield to fit the inside of the stock intake box, there is a little edge that runs along the inside. Next was to spray it with high temp paint and place the rubber seal along the top and in the back around the BMS intake housing.
Thanks and Good Luck!
      08-26-2013, 11:06 PM   #2
BigDeep1
33
Drives: 2011 535i Sport - P1, P2
Excellent idea. Can you briefly list your parts and what you did.
      08-26-2013, 11:07 PM   #3
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Any pics of the finished product? You should spray paint it or plastidip in black so that it doesn't look so out of place.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      08-26-2013, 11:14 PM   #4
tvd75
tvd75's Avatar
Away on a trip....will do so when return.
      08-26-2013, 11:16 PM   #5
tvd75
tvd75's Avatar
The installation is to help reflect heat....maybe paint it using hi temp paint.
      08-27-2013, 12:19 AM   #6
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
Dude, you might be on to something here!
Nice work
      08-27-2013, 08:42 AM   #7
Eki88
BxBadBoyy88
Eki88's Avatar
61
Drives: AW 2015 535 Xdrive
Very cool work!!
2013 AW 535Xi
      08-27-2013, 09:05 AM   #8
gtron
powerhouse
gtron's Avatar
Drives: 2014 Porsche 981 CS
cool project :]
no signature. except for this one.
      09-18-2013, 10:50 AM   #9
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
Originally Posted by tvd75 View Post
Anybody started making one? I just got the BMS intake and decided to make a heat shield for it.....
Got the supplies from Home Depot $45 and a few hours later made the heat shield. Just wanted something to reduce heat and dirt from getting into the intake. Almost completed 98%, need to add rubber seals along the top and the back around the intake housing.
Thanks
That is awesome..thanks for sharing.. COuld provide us with the part you bought from HD ? seems like an A/C duct housing...
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      09-18-2013, 05:03 PM   #10
tvd75
tvd75's Avatar
Will get the list of materials and overall dimensions later this week.
Thanks
      09-22-2013, 01:47 AM   #11
tvd75
tvd75's Avatar
DIY in full effect - sorry about the delay!
Just sold the 535 for a 550 so the intake and shield is up for sale.
      09-29-2013, 07:48 AM   #12
BigDeep1
33
Dude, amazing job!! Thanks for this DIY.
      09-29-2013, 09:53 PM   #13
tvd75
tvd75's Avatar
Much thanks!
      05-22-2014, 10:50 AM   #14
Mr Clean
Mr Clean's Avatar
Drives: F10
Absolutely Amazing DIY Im sub'ed for sure ! 5 stars!
Follow me on Instagram: MrcleanF10
      06-25-2014, 12:18 PM   #15
obiltagi3
V.I.P.
obiltagi3's Avatar
Drives: F10 535i 2011, F10 550i 2015
2015 BMW 550i  [9.00]
Has anybody else tried this, thinking of giving it a try... if it actually makes a difference?
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1
F10 535i Alpine White/Oyster
BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC
      07-29-2014, 02:13 PM   #16
chris the man
13
Drives: 08 335i prestige
anyone thought of making something somewhat like this for the N54 DCI???
5post
