10-05-2007, 10:04 PM | #1 |
27
Rep 193
My first M3 service
My car has just gone through its run-in service, so I can finally use it properly!
The service itself was painful. Nothing to do with the car, but having been told that it would take 45 minutes, I elected to wait in the dealership for it. However, it took over 3 hours!! After an hour I was bored. By two, I was grumpy. When it got to three, I shouted at them... Anyway I finally got it back and have spent most of today kicking the arse out of it to see how it performs now that I can use the full rev range (without feeling guilty! ) So, what can I tell you that I didn't know before? Well, from 6,500 revs the engine REALLY comes alive! Up until that point the accelaration is pretty much linear, but there is a definite surge over the last couple of thousand revs. Also, gear changes at the rev limiter are sweet. So sweet, in fact, that you can flat shift from third to fourth and barely even notice the change! I'll film it at some point and let you see what I mean. It really is quite incredible. Up until about 120mph it pulls pretty much as hard as the M5. It's only when you hit speeds that will land you time in jail in the UK that you really start to notice the 85bhp deficit. It will still pull all the way up to the speed limiter, but it loses a little of the effortless urgency that you get in the V10. Anyway, bedtime now, but I'll see if I can add more to this tomorrow... |
10-05-2007, 10:41 PM | #3 |
Reincarnated
245
Rep 4,227
Well done. Very interested in the video. I want to watch it and then lament the amount of time I have to wait to experience the same thing.
10-06-2007, 12:04 AM | #4 |
205
Rep 461
[QUOTE=Filthy Monkey;1501190]
So, what can I tell you that I didn't know before? Well, from 6,500 revs the engine REALLY comes alive! Up until that point the accelaration is pretty much linear, but there is a definite surge over the last couple of thousand revs. Could be this what I wrote in my post about the rumors I eard?that untill 5000 km there is a sort of electronic control of the power delivery to protect the engine from insane onwers? |
10-06-2007, 02:16 AM | #5 |
1913
Rep 4,128
Drives: M235i & G30 540i
Nice! This is def very exciting news and I to will love to see the video. Too much info is never enough if you know what I mean.
Thanx for posting.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
10-06-2007, 12:26 PM | #7 |
10
Rep 35
FM
Sounds good - looking forward to using the whole rev range for myself. My car is booked in for the run in sevice on Tuesday. They told me only an hour.....did I want to wait.....no loan car available. Luckily my salesman had offered his car to me and I've taken up the offer. Wouldn't be happy with your experience. Going to take the opportunity to leave the car with them to look at a front skirt mark which it came with - lower right corner where it seems to have been pushed into the oil cooler (?) and a slight pimple can be seen. Don't much like the thought of them dismantling for a very small mark but I'll see what they think they can do. |
10-06-2007, 07:52 PM | #9 | |
27
Rep 193
10-07-2007, 06:19 AM | #10 | |
23
Rep 289
Just went an had a look at an orange, surely it can't be that bad? Can you expand on this a little, how you spotted it etc? Do you think it's cause of the Supaguard? How will polishing it make it flatter? |
10-07-2007, 08:28 AM | #11 |
27
Rep 193
Well, it's certainly not orange, but it's definitely pimply Having spent this much on a car, I would expect a mirror finish to the paint, but that's just not the case. If you look at the panels from certain angles you can see the coarseness on the surface. I don't think it's anything to do with the Supaguard, just a poor paint job from the factory.
As for polishing to improve it, a fairly coarse rubbing compound will normally flatten the finish and remove blemishes. This can leave light surface scratches and swirl marks, but these can be removed by buffing with a very fine grit. I guess they would need to re-apply the Supaguard afterwards, although I'm not sure... I'll let you know how I get on. |
10-07-2007, 01:12 PM | #12 | |
40
Rep 2,652
Monkey,how much was the first service charge mate?? |
10-07-2007, 03:52 PM | #14 | |
58
Rep 1,075
[QUOTE=savage.ulm1;1501515]
muhahahhaha......
ZzZzZ'er |
10-07-2007, 06:29 PM | #16 |
27
Rep 193
10-07-2007, 07:38 PM | #17 | |
23
Rep 289
Hey filthy, you seem uncharacteristically preoccupied with how much you paid for the car, in a nut shell, any regrets? Bullet points are fine. It's just that I have been wondering whether - aside from having a new car that others don't - you still think the m3 is all that? You've got a 'your precise spec M3 on order'; you still gonna take it or are you gonna switch to the audi rs5??? Cheers. |
10-07-2007, 07:48 PM | #18 |
27
Rep 193
I still love the car as it puts a massive smile on my face whenever I drive it, but it just makes me sick everytime I hear the same price quoted in dollars as I paid in pounds...!!!
I will definitely still take the 'my spec' car as well, but I think I'm going to hold off until the DCT gearbox is available. There is so little I would change on the car that it's not worth wasting money going into a new car right now until there is a significant reason to. Let's hope DCT makes it here for spring. |
10-08-2007, 01:34 PM | #19 |
40
Rep 2,652
10-08-2007, 03:12 PM | #21 | |
23
Rep 289
Thanks for the reassurance!! The US cars will have a lower level of standard spec so I guess that is something. Still, with the poor USD level I just can't see how prices will be that low. |
10-20-2007, 06:42 AM | #22 |
27
Rep 193
Just found this that thread has been moved to the servicing and maintenance section and can't understand why! This is about how the car performs after the service, not about servicing the car. It should have been left in the main forum...!
