08-21-2013, 05:55 PM | #1 |
9
Rep 159
Coding and Bricking
So how many people on this forum have actually bricked their car from trying to code it? I'm sure this has been asked before but, yeah.
I understand that they have to put big scary disclaimers, but I've never bricked a phone from rooting and modding it. I can't imagine I'd do it to my car, assuming I follow all the directions to the letter. That said, losing a $300 phone isn't even close to losing a $56k car. If you brick it, is it recoverable at all? |
08-21-2013, 06:50 PM | #2 |
BimmerPost Supporting Vendor
663
Rep 1,976
Drives: 2020 G20 320i M Sport
Yes it is possible to potentially brick your car but keep in mind that you car is made up of many ECU's which reports via Canbus so if you're coding one specific module and say that module loses power, it will be that specific module that you will have to worry about. Let's say you were making some changes to the instrument cluster and for some reason, something goes wrong while coding, it would only be the instrument cluster that needs to be recovered.
In most cases, you can either push the cafd back down via E-sys and if that doesn't work, you will probably need the dealer to reprogram the car with their software. In extreme cases, you will probably need to replace that specific module if it is beyond repair and no longer responds. If you're careful and know what you're doing, I'd say the risks are minimal but it wouldn't necessarily mess up your entire car if something goes wrong. Last edited by steve@codemybimmer; 08-21-2013 at 07:06 PM.. |
sspade2464.50 |
08-21-2013, 07:09 PM | #3 |
9
Rep 159
Okay, I see now. That makes perfect sense. I think I'll probably invest in a cable and start messing around because things like unlocking the door when you turn off the power or changing the measurement units on the sport display are totally worth 20-30$!
08-21-2013, 08:15 PM | #4 | |
3216
Rep 2,385
View it like the Windows Registry. Do it wrong and you might screw things up, but it's very hard to do wrong. It's pretty simple if you're careful. |
08-21-2013, 08:33 PM | #5 |
10413
Rep 40,653
Drives: 2018 Alpina B6 650ix GC
Bricking can occur during Programmimg (flashing), as new firmware is being written to an ECU.
Bricking can not happen from Coding an ECU.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-22-2013, 12:10 AM | #6 |
663
Rep 1,976
08-22-2013, 05:09 AM | #7 |
10413
Rep 40,653
The ECU can be recovered, usually with VO Coding, and if not with Programming. It it does not become bricked. A bricked ECU is completely dead, and needs replacement.
03-13-2019, 11:22 AM | #8 |
Rep 46
Hi Shawn
I have a F30 where I flashed the bkombi, and I lost connection to the car (my fault). New in E-Sys I cant find the bkombi any more, so I cant just reflash it. Do you think its completly dead, or can I do an emergency flash with nfs ? |
03-13-2019, 12:36 PM | #9 |
10413
Rep 40,653
I have no way of knowing really. Maybe it is bricked or maybe not. When you use Read ECU with motor running, not Read SVT, do you see bkombi?
03-13-2019, 01:18 PM | #10 |
2465
Rep 5,457
Drives: F30
I would highly recommend BimmerCode. Very easy to use, yet effective.
Price is right as well. |
03-15-2019, 08:10 PM | #12 |
170
Rep 468
I lost FEM while coding. Voltage dropped below 11.5v and the FEM bricked. All lights came on..Lesson learned. Had to get a new FEM, as I didnt know anyone to reflash the eprom for me with original files
Keep the engine running or connect a stable power supply. |
03-15-2019, 08:12 PM | #13 |
10413
Rep 40,653
Sorry, I have no idea.
03-20-2019, 07:57 AM | #14 |
39
Rep 134
what kind of coding tools you used? esys?
Instagram: @tafikhulafaa & @88tuning.id
03-20-2019, 08:10 AM | #15 |
170
Rep 468
Yes Esys. But I guess regardless of a tool this can happen with any other coding/programming device.
I remeber back in the day this was a common issue with NCS expert and FRM modules bricking due to voltage fluctuations. I think F30 batteries are much stronger gel batteries and this even is not as often, but yeah can still happen. FEM then shows as red in ista, no communication. There a similar thread on here about those issues. |
03-20-2019, 08:16 AM | #16 | |
39
Rep 134
but that's extreme though, i thought it's gonna be blue one in ISTA (programming abort). if it's blue, there's still hope to revive those module lol. hope all can be solved.
