oil change @ 2000 kms?.....
08-13-2013, 11:30 AM | #1 |
65
Rep 515
i bot a 2013 e92 coupe 335xi that had been sitting on a lot for a year with 39kms on it
it is going to the dealer for service on a steering column issue tomorrow, i was thinking about getting the oil and filter changed since i am now past break in and the oil is well over a year old now waste of money or good idea? |
08-13-2013, 03:23 PM | #2 |
347
Rep 1,076
Couldn't hurt. If it sat, was it started frequently but shut down before it warmed up? That would be a good reason to change the oil even it hasn't been driven.
08-13-2013, 05:35 PM | #3 |
81
Rep 734
Doesn't hurt for sure. The only thing is whether or not the factory fill is a special break in oil vs what the dealer will give you. Double check on that and you're good to go!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
08-13-2013, 05:45 PM | #4 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Break in oil is only used in the M3 and changed at about 1,200 miles.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-14-2013, 07:20 PM | #5 |
124
Rep 5,627
If the same oil has been in the car for over a year, it is due for a change, regardless of mileage. The dealer will do it under the covered maintenance - assuming you are in North America.
(See your Warranty/Service manual re low mileage oil changes.) Tom |
