08-13-2013, 09:50 AM | #1 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Track wheels/tires... wider or lighter?
I'm considering a few options for wheels/tires, and would appreciate advice from experienced track drivers. These will serve double duty as DD and occasional track use, and I would prefer to stick with a 19" setup unless it's a significant compromise on the track.
The plan is to go with a square setup. In terms of width, would I be better off squeezing a 9" wheel up front at the expense of a few pounds of unsprung weight per wheel? From what I've read, when it comes to grip, width of the wheel is more important than tire tread width (i.e. a 245 versus 255 tire on an 8.5" wheel makes little to no difference, but either tire on a 9" wheel will provide more grip), but weight is also certainly a strong consideration... So which is more important?
Ahead of the curve for specF30
08-16-2013, 10:23 AM | #2 |
558
Rep 1,477
Drives: 335i
Anyone?
08-16-2013, 03:28 PM | #3 |
67
Rep 210
19" are a bit tall and heavy. I think 245/40/18 are ideal. I like my Apex Arc 8s; 18x8.5 are a nice size. Contact jbass on this forum if interested.
08-16-2013, 03:30 PM | #4 |
558
Rep 1,477
Drives: 335i
8.5 or 9"?
08-16-2013, 04:05 PM | #6 |
558
Rep 1,477
Drives: 335i
So you felt like the extra wheel width was worth the weight penalty?
08-17-2013, 06:21 PM | #8 |
558
Rep 1,477
Drives: 335i
Depends on camber and offset. A lot of guys are running 9s up front (without fender rolling) with no rubbing.
08-17-2013, 06:50 PM | #9 | |
99
Rep 1,050
More negative camber probably wouldn't help but it would allow a 255 in there!! |
08-29-2013, 10:55 AM | #11 |
558
Rep 1,477
Drives: 335i
OK, I pulled trigger on a set of Apex ARC-8s in 18x9 et42 in satin black. At 18.65# per wheel, I am willing to stick with 18s. The more I learn, the more it seems that 18s are the way to go for performance anyway; 19s are for boulevard cruising.
09-03-2013, 12:43 PM | #12 |
99
Rep 1,050
09-03-2013, 01:51 PM | #13 |
558
Rep 1,477
Drives: 335i
Just got confirmation today that they arrived at the shop. Which is exciting... but it will be more exciting when the car arrives
My 2014 335i should be delivered in a week or so; once I pick it up, I'll get the wheels installed and post some pics. |
09-03-2013, 08:11 PM | #14 |
44
Rep 349
Same setup here. I'll post some dirty pics tomorrow with m perf brakes and suspension. Get your wallet out lol
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
09-11-2013, 03:23 PM | #15 |
248
Rep 1,436
Guys I'm new in the tire sizes stuff, but I crossed on the internet with these camber tires, I have a 225/50 R17 7.5" front and 255/45 R17 8.5" rear but they only have 245/45 and I don't know if it will fit in the front..so I contact camber tires and he (John Scott) said it might he has to see the car but I live in Egypt anyone have tried 245 in the front ?
12-02-2013, 09:38 PM | #16 | |
558
Rep 1,477
Drives: 335i
12-03-2013, 04:09 PM | #18 |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
looks nice
IMHO you should pop-out the APEX center caps and put the roundel ones back in - they'd touch off the black wheels with the blue paint and blue calipers nicely |
12-03-2013, 04:47 PM | #19 |
558
Rep 1,477
Drives: 335i
Thanks! Re: the center caps, I am usually not a fan of the roundels on aftermarket wheels - particularly black wheels. But you do make a good point about the blue calipers... might have to give that a try.
12-06-2013, 05:32 AM | #20 |
Infidel
122
Rep 1,102
My winter wheels are also black and look similar to yours + I got the M brakes also, I too am not a fan of putting the roundel on aftermarket... but I´m considering it cause it does look better breaking up the black.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
01-03-2014, 11:59 PM | #21 |
649
Rep 4,323
You decided to not stagger then? How was it on the track?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
01-04-2014, 02:35 AM | #22 | |
301
Rep 1,591
I think I'm set on 18 x 8.5 +35 square for my dedicated track wheels, but deciding on tire sizing still 235 or 245
-JustinNApproved
