Warning indicator
08-10-2013, 07:04 PM | #1 |
Rep 51
Warning indicator
I have a warning icon light up on my car (2007 328xi coupe) that shows a light bulb with an exclamation mark in the center. I looked it up in the manual and it indicates that an external light has burned out.
Ok, the problem is that none of my lights are burned out, but the warning indicator continues to show up. Any ideas why (a short or something?) it keeps coming on? Also is there a way I can reset the computer to maybe keep it from coming on? Any help would be appreciated. |
08-11-2013, 09:04 AM | #3 |
Rep 138
go through the check on your stalk. when you get the error, hold down the BC button. should give you a cid number. search the number. its common for this to happen with the tail lights.
08-11-2013, 12:02 PM | #4 |
19
Rep 184
Happened to me last week. Pushed in the BC stalk and it showed CC-ID 134 (RR brake lamp). This used to happen with my E36. Popped out the holder, pulled out all the bulbs, they looked ok, cleaned all connectors in the holder with an emory board, reinsterted all bulbs, no more warning bulb with exclamation point! I ordered all new bulbs off Ebay, just in case. The bulb holder, sometimes a problem, can be had for about $17.
08-11-2013, 06:04 PM | #6 |
295
Rep 2,202
Either a bulb has failed or it on it's way.use method mentioned above with the BC stalk to pin point where to look for affected lamp(s). Good luck.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
08-11-2013, 06:25 PM | #7 |
1045
Rep 5,660
When I encountered that, it was due to a reverse travel indicator light. It is also possible that you have a loose bulb or connector.
I once got that warning you noted and did nothing about it and it went away.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
08-11-2013, 06:36 PM | #8 |
60
Rep 1,024
This happened to me twice. Once it was a turning light (the innermost of the two bulbs in the headlight) and once it was one of the bulbs in the tail light that couldn't really be seen.
08-11-2013, 09:29 PM | #9 |
Rep 54
I know this is an E90 forum, but I had an E46 2002 325 XI which in its later life would show a lamp in my right rear having a problem. I inspected and tested the lamps - all were OK, but the diagnostic would still appear. I cleaned the connectors - the diagnostic would still appear. I replaced the housing for the lamps - the diagnostic would still appear. My success? I turned on my headlights. After approximately 15 seconds, I could turn off the headlights and the diagnostic would go away.
I never figured out why it behaved that way and it was not consistent. Sometimes the diagnostic would not appear for several weeks. But when it did, turning on the headlights for a few seconds made the diagnostic go away. |
08-11-2013, 10:00 PM | #10 |
Leeeroy Jankins
31
Rep 423
I've had this warning light for like 3 months now. Too lazy to fix it. Mines the "left cornering light malfunction" and all my lights work too.
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
08-12-2013, 01:01 PM | #11 |
Rep 51
This may sound stupid, but when you say BC button do you mean the button on the end of the stock?
08-12-2013, 02:50 PM | #12 |
164
Rep 401
This happens with the BFD light quite often, and the older e9x chassic vehicles did have a problem with the bulb holders for the tailights. I tightened my holders up using needle nose pliers and a pick when this happened to me. All has been well now for over a year since it happened
08-12-2013, 02:53 PM | #13 |
81
Rep 6,092
yes. the button at the end of the turn signal stalk.
08-13-2013, 12:45 PM | #14 | |
Rep 51
Any help is greatly appreciated. Thanks. |
08-14-2013, 03:57 PM | #16 | |
164
Rep 401
08-15-2013, 11:00 AM | #17 | |
Beamer Mantic
82
Rep 1,191
CLick->The BMW WDS might help
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
08-15-2013, 01:09 PM | #18 | |
164
Rep 401
08-15-2013, 04:20 PM | #19 |
Beamer Mantic
82
Rep 1,191
Got it... Thanks...
2006 325i
