A/C diagnosis - Am I getting screwed?
08-07-2013, 04:42 PM | #1 |
Rep 17
So, it's been hot here and my AC was only blowing partially cold air out of the passenger side vents, warm air out of the rest
Sounded like low R134a to me. They dilemma. I have buddy in a shop that could do a Evac/refill and vacuum test for a good deal. But, the car is CPOd, so if they did find a leak I would want to take it to BMW to get the leaky part replaced. Since it was probably low on R134a and it's a sealed system there is most likely a leak somewhere. After speaking with the owner of my buddies indy shop we all figured just going to BMW was the best bet. Got the call this morning that it was in fact low but the vacuum test came back good and no dye was found anywhere with the UV light. I had a feeling this might happen. Looks like i'm paying stealership price $320 for the ac evac/refill, not a $50 co-pay. Here's the kicker. It wasn't just slightly low. There was only .35lbs left in the system. This is a 1.5 lbs system. To me that sounds like a lot to chalk up to normal loss in the system. What do you guys think? There's got to be a leak somewhere right? Is there an amount of loss noted in any tech manuals that is listed as acceptable? This is a 2009 328 E91 xdrive with no HVAC work noted in any of the BMW service records. In their defense, the SA did tell me to swing by in a couple weeks and he would have a tech pull it in and check with the UV light again. I will also be doing that myself. What's the verdict? Screwed, normal? It is blowing nice and cold so at least I have that going for me |
08-07-2013, 04:52 PM | #2 |
19
Rep 345
Drives: '08 335i, '03 Kawa Z1000
I'm no expert, but that sounds like a very large loss of fluid for a closed system. Did you ask the dealership where all that refrigerant could have gone? I'd be interested in hearing their explanation.
08-07-2013, 04:56 PM | #3 |
Too much is never enough
655
Rep 3,079
If it's a slow leak (likely) it won't immediately be evident with the UV light. I suspect that now that it's fully charged, there's a chance it will probably pick up the pace and there may be signs when you do take it back.
As an aside, it's possible the evaporator is leaking which is impossible to visibly inspect (buried in the dash). I suspect that after a period of time there would be residue on the condensate drain line if the evaporator is indeed leaking. Did you find out if you'd be compensated for the work if they determine at a later date that there IS a leak? I suspect you would be. I don't fault them for charging for the work in the absence of an obvious fault. Joe Customer could easily release some gas either intentionally or unintentionally. I think they're going about it properly. |
08-07-2013, 04:57 PM | #4 |
655
Rep 3,079
It's a gas at atmospheric pressures and temperatures. Colorless and odorless.
08-07-2013, 05:00 PM | #5 | |
19
Rep 345
08-07-2013, 05:17 PM | #6 |
655
Rep 3,079
08-07-2013, 05:35 PM | #7 | ||||
Rep 17
I did bring up the evaporator and he mentioned that they do look in the vents with the UV but that doesn't seem like a very fool proof troubleshooting technique to me. I'll make a note to keep an eye on the condensate drain line. Quote:
I do think they are going about it properly as well. I don't think they're maliciously saying there is no leak or that they didn't troubleshoot it properly. In his defense the SA didn't seem like he was trying to hose me over or anything. Just that the data provided din't really add up. As someone else asked. I'm no expert either and that just seemed like quite a bit of gas to leak out under normal circumstances. thanks |
08-07-2013, 06:22 PM | #8 |
39
Rep 1,558
Standard practice at my shop would be to pressure test the system with nitrogen if the system was that low. Using vacuum as method of leak detection will only show a very large leak (in my experience). Secondly why were they looking for dye in the first place, if the system has never been worked on before? They do not come with dye in the system from new, not that I've ever heard of.
This almost sounds like a way to get some cash out of you before the "big hit" they will take on the cpo repair.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
08-07-2013, 06:37 PM | #10 | |
655
Rep 3,079
08-07-2013, 08:04 PM | #11 | |
39
Rep 1,558
The system should be nitrogen tested and the leak found and fixed properly. They are prolonging a problem imho.
08-07-2013, 08:12 PM | #13 |
39
Rep 1,558
Very true but, they either do it the first and find the source of the problem the first time or prolong it until his warranty is over, then guess who gets the bill and the previous bill to re-chagre a leaking system, which it pointless.
08-07-2013, 08:23 PM | #14 |
557
Rep 5,367
I agree with BavarianFanatic, ive personally evac/charged ac systems before and used dye to detect a leak. My experience was NO leak found on the initial vacuum test. Next i added dye into the system (r12) and found NO leak during that time (blowing cold). A month later it went from cold to cool to nothing. NOW the dye method works, it all leaked out from the compressor.
I would go back to the SA and get something in writing that you may have a faulty compressor and that they should replace if any a leak is found within a given time/warranty.
You can follow my builds on IG: Tee212 |
08-07-2013, 09:26 PM | #15 | |
22
Rep 414
If you have documentation showing the problem was there before the warranty ran out you at least have a fighting chance of getting it covered later. I just had the same problem with my 08. I took it to my indy shop that I trust and he said the compressors have problems often on these and he expected thats what was wrong. After checking it out he said he couldn't find any leaks at least big enough to detect so he just filled it up and it has been working fine so far but that was only about a month ago. I was about 3/4 of a pound light.
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
08-08-2013, 08:05 AM | #18 |
181
Rep 1,681
Now that there's UV dye in the system and it's fully pressurized, the leak will probably be detected shortly. Typically leaks get bigger and the system will lose pressure faster. I recently went through all this, had a tiny hole in the condensor and couldn't find it even with dye at first. Then it went from loosing refrigerant in a month to about 2 hours as the leak got bigger.
Sometimes, there can be an issue with the schraeder valves themselves. But you are correct that the systems are entirely sealed so unless it's been like 20 years, you shouldn't lose refrigerant without there being a problem. |
08-08-2013, 12:24 PM | #19 |
164
Rep 401
Definitely not a normal loss. I used to do automotive A/C work all the time (I was the only MACS certified guy in my shop prior to getting out of the business). I'm curious if they even performed the vacuum test correctly. Some technicians simply check to see if the vacuum achieves a particular level while sucking down the system, but if the rate in which the machine pulls a vacuum is greater than the rate in which the leak in the system causes a pressure loss then this method is useless. The proper way to perform the test is to place the vacuum on the system, then shut off the vacuum pump and let the system sit and visually watch the gauge to see if it's still holding the same vacuum level after, say, 15-20 minutes. If it is, then I'd let it sit even longer in your case. With the amount of loss you mentioned, it is anything but normal. It's not uncommon for vehicles that are 10+ years old to still be blowing cool air on their original factory charges. If test is still inconclusive, then I would go ahead and recharge and dye the system then tell the customer to come back in a week or so to check over with a UV light. If no leaks are detected visually, then go around the evaporator area with a sniffer (they make tools that can detect this stuff though it is odorless) which can easily aid in determining if the evap core is the source of the leak prior to ripping the dashboard apart. My 2 cents
08-08-2013, 01:07 PM | #20 |
Rep 17
Just to clarify. The dye test was performed after the system was recharged.
The exact steps listed were Vacuum Test and Leak Test performed, as well as noting that the system was recharged with dye added. So I'm assuming no nitrogen pressure test was done. Question. Who is on the hook for CPO warranty work? Is that different than normal factory warranty work? I always assumed the dealer gets paid the shop rate for the job one way or the other. Do they have to eat the labor costs for warranty work? |
08-19-2013, 09:50 PM | #21 |
80
Rep 333
Just for the sake of documenting for others who may do a search, I had my AC fixed today - they replaced two shrater/shrator (however they are spelled) valves and replaced the refridgerant. Blows ice, ice cold air now.
08-19-2013, 10:18 PM | #22 |
89
Rep 3,732
Drives: BMW S1000XR
I assume you had the same symptoms? Just to get a bit of cold air I had to close the two middle vents and rear vents. Still not cold enough. Thanks for the information. I'll have the dealer check the A/C shrader valves.
BMWCCA member |
