Dealer killed my steering wheel audio controls
08-06-2013, 12:47 PM | #1 |
41
Rep 692
Took my car into the dealer for a failed water pump last week. They changed the water pump, t stat, and both turbos. Upon their road test my SA said a steering angle sensor error popped up. So they reset the module and road tested the vehicle again and the error did not return. However when I went to pick up the car my steering wheel controls no longer worked.
I brought my car back to the dealer the next morning and my SA had a technician look into the problem. They said my SAS was faulty/failing which caused the steering wheel controls to stop working. Thoughts on this situation? I'm trying to get the dealer to pay for the new SAS since the steering wheel controls worked perfectly prior to bringing the car in for servicing. I originally assumed they had forgotten to plug in the steering wheel controls however my SA says the steering wheel never came off. |
08-06-2013, 01:59 PM | #2 |
164
Rep 401
Resetting the module will not cause the steering wheel controls to lose function. It is true that none of the repairs they performed would require the wheel to come off, so if they are telling the truth then the dealer is not at fault. I'd chalk it up to coincidence. The SAS failure is common with these vehicles, however, I have never heard of the SAS sensor causing audio controls to lose function. They're entirely different systems, so I think they are blowing smoke up your arse with that comment
08-06-2013, 04:38 PM | #3 | |
41
Rep 692
08-07-2013, 09:02 AM | #5 |
164
Rep 401
If it's the slip ring (unless the slip ring failed on its own which is like a 1 in a million chance), then they had your steering wheel off. But yes if the slip ring binds, and the wheel is turned, then the wiring for the steering mounted controls will be torn
