how to rotate the engine on 6AT
08-05-2013, 07:37 PM | #2 |
16
Rep 150
Put it in neutral and turn the crank bolt
2008 135i RIP
2016 M3 |
08-05-2013, 08:00 PM | #3 |
Stupid Idiot
134
Rep 827
Actually doesn't even have to be in neutral. The flexplate and torque converter can rotate in park.
And yeah, It's either a 21mm or 22mm socket. Having slight memory loss on that one....
08-05-2013, 10:18 PM | #5 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
You will probably need to pull the spark plugs too...otherwise it will be very difficult to crank. The crank bolt is on the front of the engine, at the center of the largest pulley.
Honestly, not to be an ass, but if you don't know where the crank bolt is, this may not be a job you should tackle on your own. There is no issue getting some carb cleaner in the piston chamber, it will just burn off....as long as its not a ton, because you could hydrolock if its too much (that would be hard to do) |
BillyG1.50 |
08-05-2013, 10:42 PM | #7 |
Reborn
87
Rep 1,217
08-06-2013, 07:37 AM | #8 |
102
Rep 775
Serious... or troll?
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
08-06-2013, 07:56 AM | #10 | |
137
Rep 1,202
08-06-2013, 08:27 AM | #11 | |
915
Rep 3,456
Drives: Harrop E90 M3
08-06-2013, 08:36 AM | #12 |
19
Rep 259
+1
This is what I did (kinda, just rigged it up with stuff I had laying around the garage). Quick and easy.
2007 335xi 6AT | Cobb Stage1+ | BMS DCI | VRSF 7" IC | FA 500 400#F/600#R | ARC8 17x9 et30 | RE-11a 255/40/17
Parting out car. For sale thread here: http://www.e90post.com/forums/showthread.php?t=1167583 |
08-06-2013, 08:38 AM | #13 |
292
Rep 2,898
08-06-2013, 10:51 AM | #14 |
10
Rep 134
Remove radiator fan and use a 23mm socket (going off memory, I don't think it was 21 or 22mm but 23mm). Radiator fan is one torx bolt on the passenger side of the fan near the hood, one torx on the drivers side underside of the fan where the heat exchanger mounts to the fan, and one clip on the drivers side about 60% of the way up the fan.
You'll need a long ratchet or what I did is buy a long metal pipe that I put on the end of my ratchet. The valves sit at top dead center for quite a few cranks before finally pushing down and opening. I would always make sure to open the valves, close them, and then give it one or two more cranks to ensure top dead center. |
08-06-2013, 10:00 PM | #15 |
king of the hills
92
Rep 2,915
How does that help you? The valves are still there, it doesn't matter one bit whether or not the intake manifold is on or off.
Some say they can get it to turn with a big breaker bar or pipe, but it would make your life a lot easier if you took the plugs out to hit TDC so there is no compression in the cylinder and much less resistance to turning the crank bolt. I have not yet done this myself, but I am using my experience on other cars trying to turn the crank bolt. |
08-07-2013, 02:20 PM | #16 |
Rep 10
Drives: 08 335xi e92
Hopefully this wasn't the wrong way, but I just disconnected all the coils and hit the start button. I got really lucky, When I first got to the valves, I had 3 closed. After cranking it, I had the other 3 closed on the first attempt.
05-16-2019, 08:31 PM | #18 |
1905
Rep 6,968
Drives: 2007 Black/Black 335i e90
PichaDis11295.00 |
05-17-2019, 06:29 AM | #19 |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
05-17-2019, 12:44 PM | #20 |
1905
Rep 6,968
06-05-2019, 08:40 PM | #21 | |
295
Rep 2,202
06-06-2019, 06:28 AM | #22 | |
654
Rep 1,893
Also, if you have ever tried to loosen that crank bolt, you would note that it takes a whole lot more force than what is required to rotate the engine, even with the spark plugs still in place. Loosening the crank bolt is not really much of an issue if you wished for some reason to reverse rotate the crank. However, it you were setting the cam timing, you would want to rotate the engine in direction it operates so that tolerances in the chain and tensioning system would not become an issue. Similarly, if you are looking for TDC, you want the piston to approach in the same manner that it would during normal operation. |
