BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 335d Tank Venting
      08-04-2013, 10:18 AM   #1
craignucks
Nude Member
Drives: 335d M-Sport
335d Tank Venting
Total noob question for anyone who has a 2009-2011 335d. Is there any way to 'vent' the tank while filling? I just moved up from a VW TDI. After the pump hit the stop point, you could press on a valve with the nozzle to let the air out of the chamber. This technique would allow you to squeeze an extra 13L of fuel into the tank.
Is this a VW-only phenomenon? Can't seem to find any info on this online.
      08-04-2013, 11:41 AM   #2
montr
Drives: 2010 335d, 2018 430i G-Coupe
I am not aware of this problem with the 335d. At the service station, when the filling fuel pump stop automatically, there is little room left for more fuel without over-fuelling.
      08-04-2013, 12:22 PM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
VW only. The only problems we've had were wrong-sized nozzles that don't open the miss-fueling safety interlock - use your (provided) funnel but be careful with the shutoff if you do.
I've never been able to put even a quart in after the nozzle shuts off.
      08-04-2013, 01:55 PM   #4
craignucks
Nude Member
Thank you, floydarogers! I'd been experimenting with ways to defeat the auto-shutoff to try and squeeze a few more drops into the tank like I did with the TDI. The only thing that I was successful with was spilling a bunch of diesel onto the rear body panel, tires and my shoes.
      08-04-2013, 01:59 PM   #5
craignucks
Nude Member
It wasn't really a 'problem,' montr. It was more of an awesome 'feature' on the TDIs that added about 200km to your range.
      08-04-2013, 02:25 PM   #6
Hoooper
213
Drives: 335D
Its only a "feature" if the tank doesn't normally fill all the way up. If you run this car close to empty then you can easily fill 16 gallons on the 16.2 gallon tank.
Tags
diesel, fuel tank, vent
