BMW specific code
08-01-2013, 01:55 AM | #5 |
Rep 131
Not to sound like an ass, but a simple search will turn up results.
Here is a common one that seems to come up on a regular basis http://engine-codes.com/p0070_bmw.html#ixzz24TypLe16 Last edited by Bmr3sn; 08-01-2013 at 02:03 AM.. |
08-01-2013, 07:34 PM | #8 |
Rep 131
Some codes I found with google
Cant confirm they are correct, but its a starting point? I thought I read the B can actually mean 8?...... Maybe someone else can confirm? If so, a few and listed below. P1083 Fuel Control Mixture Lean (Bank 1 Sensor 1) (BMW) P1084 Fuel Control Mixture Rich (Bank 1 Sensor 1) (BMW) P1085 Fuel Control Mixture Lean (Bank 2 Sensor 1) P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1) (BMW) P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1) (BMW) P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1) (BMW) P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2) (BMW) P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1 (BMW) P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1 (BMW) P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2 (BMW) P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2 (BMW) P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1) (BMW) P1095 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1) (BMW) P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1) (BMW) P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1) (BMW) P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2) (BMW) P1313 "A" Camshaft Position Plausibility (BMW) P1317 "B" Camshaft Position Plausibility (BMW) P1320 Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses P1323 Ignition Control (IC) Module 24x Reference Circuit low frequency P1327 Knock Sensor 2 (Bank 1) Low Input (BMW) P1328 Knock Sensor 2 (Bank 1) High Input (BMW) P1332 Knock Sensor 4 Low Input (BMW) P1333 Knock Sensor 4 High Input (BMW) P1340 Multiple Cylinder Misfire During Start (BMW) P1341 Multiple Cylinder Misfire With Fuel Cut-off (BMW) P1342 Misfire During Start Cylinder 1 (BMW) P1343 Misfire Cylinder 1 With Fuel Cut-off (BMW) P1344 Misfire During Start Cylinder 2 (BMW) P1345 Misfire Cylinder 2 With Fuel Cut-off (BMW) P1346 Misfire During Start Cylinder 3 (BMW) P1347 Misfire Cylinder 3 With Fuel Cut-off (BMW) P1348 Misfire During Start Cylinder 4 (BMW) P1349 Misfire Cylinder 4 With Fuel Cut-off (BMW) P1350 Misfire During Start Cylinder 5 (BMW) P1350 Ignition Control System P1351 Misfire Cylinder 5 With Fuel Cut-off (BMW) P1352 Misfire During Start Cylinder 6 (BMW) P1353 Misfire Cylinder 6 With Fuel Cut-off (BMW) P1354 Misfire During Start Cylinder 7 (BMW) P1355 Misfire Cylinder 7 With Fuel Cut-off (BMW) P1356 Misfire During Start Cylinder 8 (BMW) P1357 Misfire Cylinder 8 With Fuel Cut-off (BMW) P1358 Misfire During Start Cylinder 9 (BMW) P1359 Misfire Cylinder 9 With Fuel Cut-off (BMW) P1360 Misfire During Start Cylinder 10 (BMW) P1361 Misfire Cylinder 10 With Fuel Cut-off (BMW) P1362 Misfire During Start Cylinder 11 (BMW) P1363 Misfire Cylinder 11 With Fuel Cut-off (BMW) P1364 Misfire During Start Cylinder 12 (BMW) P1365 Misfire Cylinder 12 With Fuel Cut-off (BMW) P1370 Ignition Control (IC) Module 4x Reference too many pulses P1371 Ignition Control (IC) Module 4x Reference too few pulses P1375 Ignition Control (IC) Module 24x Reference High Voltage P1376 Ignition Ground Circuit P1377 Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison P1380 EBTCM DTC Detected-Rough Data Unusable P1381 Misfire Detected-No EBTCM/PCM Serial Data P1384 Knock Sensor 3 Circuit (BMW) P1385 Knock Sensor 4 Circuit (BMW) P1386 Control Module Self-test, Knock Control Baseline Test Bank 1 (BMW) P1396 Crankshaft Position Sensor Segment Timing Plausibility (BMW) P1397 Camshaft Position Sensor "B" Circuit |
08-01-2013, 08:01 PM | #9 |
213
Rep 2,210
08-01-2013, 09:12 PM | #10 | |
Rep 186
It's actually. A "B" |
08-03-2013, 09:58 PM | #13 |
Rep 186
Is anybody a actual BMW technician that could do me a solid? And look these up at work on their free time? The car is running in limp mode.
