Britalman installed, loss of power... what could it be???
10-01-2007, 06:44 PM | #1 |
OEMconcept
174
Rep 5,593
i just finished installing my Britalman intake, followed the instructions step by step....
brought the car on the first test run, and wow, its so much slower.... the car accelerates in stages.... then when you hit second, there is a huge dead spot.... so the car shifts into second gear, while accelerating hard, and the car feels like it lost traction, and it cut the power, then feels like it regained traction and all the power is applied to the wheels..... its very weird... anyone have an idea of what it could be??? |
10-01-2007, 07:10 PM | #2 | |
134
Rep 3,132
Are you sure thats not actually what's happening? DTC off might be the solution
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
10-01-2007, 09:36 PM | #3 |
OEMconcept
174
Rep 5,593
10-01-2007, 10:24 PM | #4 |
539
Rep 18,123
Exhaust leak? A before and after dyno would be much more accurate than the butt dyno.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
10-01-2007, 10:33 PM | #5 |
OEMconcept
174
Rep 5,593
10-02-2007, 03:10 AM | #7 |
539
Rep 18,123
wow self!
10-02-2007, 03:43 AM | #8 |
114
Rep 3,431
montrealbimmer, try this:
first make sure everything is connected properly in the engine bay, then disconnect the battery terminals in the back of the trunk, let it sit there for a bit, and then reconnect, go back out there and do another test drive, this allows the MAF to start out fresh, it fixed my slight laggy response on my previous gruppe m rep intake, see if it helps a bit
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black) |
10-02-2007, 08:30 AM | #9 |
Perf BMW mag issue 147, 159
414
Rep 6,803
drive it a few days and let the adaptations change to adapt the new intake
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
10-02-2007, 08:35 AM | #10 |
335
Rep 7,719
10-02-2007, 09:27 AM | #11 |
OEMconcept
174
Rep 5,593
10-02-2007, 12:40 PM | #12 |
Moderator
497
Rep 27,441
very possible it's the intake.
britalman intake is the same design as fujita (they probably get them from fujita and relabel them). if you read up on fujita, you'll see all the disappointing responses. imho, it's a bad intake design.
10-02-2007, 01:57 PM | #13 | |
OEMconcept
174
Rep 5,593
im gonna try to tighten the rings around the throttle body a little more, maybe there is air getting in somewhere.... |
10-02-2007, 02:46 PM | #14 |
181
Rep 4,038
well ive read mixed aswell.. didnt some cars stall if you did somthing on the highway or somthing?
id sell it and get the gruppe m rep for $340 shipped im so happy with mine and the power is there ! |
10-02-2007, 05:07 PM | #17 | |
Modder Raider
753
Rep 8,633
Drives: M3
I found that I put everything together fine, but i forgot to tighten down the actual filter! The little extra air that was coming in through the opening was affecting the MAF. Check all of your connections once again.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
10-02-2007, 05:24 PM | #18 |
61
Rep 1,120
It sounds like a flow vs. metering problem. Definitely double check all connections to ensure no leakage. Also, this may sound silly but was there anything maybe trapped in the intake or filter such as packaging for the intake?
2007 BMW 335xi 6MT TiAg
10-02-2007, 05:29 PM | #19 |
OEMconcept
174
Rep 5,593
i checked everything out.... i tightened all the harnesses, real tight.... gonna take it for a test run after supper.... ill report back to you guys...
10-02-2007, 05:40 PM | #20 |
576
Rep 6,750
Did you spray the filter with oil? Sometimes an excessive amount can mess up your mass flow air sensor.
10-02-2007, 06:06 PM | #21 |
OEMconcept
174
Rep 5,593
