Couple questions coming from a previous muscle car enthusiast
07-29-2013, 07:44 PM | #1 |
Rep 10
I owned a 2008 Mustang GT which i sold off because i need a more serious/business/formal car. Im looking at a 2011 325i M sport with lots of nice things the mustang never had. My major concern is that i loved sliding/drifting my mustang around occasionally, it just slipped with a light brush to the accelerator. Now, ive lurked the forums and found some mixed opinions about people being afraid of the car with the DTC/ DTS thing off and the car not having an lsd. I just want to know if i can slide the car around corners like i used to do with my mustang if i slam the accelerator harder. When i took it for a test drive the dealer wouldnt allow me to turn the assists off .
Dont get me wrong by no means im hating on the e90, i love every aspect of it. Kind of like this, without having to weld/change the differential or without having to have a biturbo to do so. or am i better of getting a camaro or another sort of sport car? |
07-29-2013, 07:48 PM | #2 |
86
Rep 1,849
You can slide a 335i about somewhat, but the e-diff set up will reduce the life of the rear brakes by a good bit. You can also warp the rotors (I know, I have). It won't power-slide like your mustang though.
You can always put an LSD in it for a few grand, if you want. That plus a mild tune from a JB or Cobb or Dinan or even a BMW PPK will have you sideways as much as you like.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
07-29-2013, 07:59 PM | #3 |
86
Rep 1,849
For more on the e-diff in modern BMWs:
http://www.1addicts.com/forums/showthread.php?t=719012
07-29-2013, 08:00 PM | #5 |
19
Rep 564
Not happening without an LSD. My boss has a new GT and slides it around everywhere. Every time he does it I get so jealous, and think my 335 sucks a big fat one for not having an LSD.
07 AW E92 335 6MT [18" OEM 193's For Sale, PM me] OEM Aero Lip | OEM Gloss Black Kidney Grills | KW V2 | Vorsteiner CSL trunk | M-Tech Rear Bumper | LCI Rear Taillights | Angel ibright Angel Eyes | 3000K HID fogs | 6000k HID low beams | AFE DCI | Full LED conversion |
07-29-2013, 08:03 PM | #7 | |
22
Rep 414
If your serious about buying one go find a dealer that will let you actually drive the thing. I got pulled over on a back road going over 120 on a test drive, luckily the dealer got yelled at more for letting me do it and for constantly testing on this road and I just got a warning Apparently the people that lived along it had called the cops and complained about them testing cars at high speeds often I guess after that they had to find a new road. They were a rare and epic dealership but I have been on many test drives and never had anyone tell me I couldn't turn stability or traction control off.
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
07-29-2013, 08:29 PM | #8 | ||
Rep 10
i read the E-dif thread and said you can drift just fine, i guess im trying to schedule another test drive tomorrow and see if i can get away with trying to drift cause there are so many different opinions here, |
07-29-2013, 08:34 PM | #9 | |
Came to the N55 Darkside
1112
Rep 12,740
07-29-2013, 08:49 PM | #10 | |
86
Rep 1,849
All the pro drifters pretty much consider an LSD to be absolutely necessary to their racing.
07-29-2013, 08:50 PM | #11 |
86
Rep 1,849
From the wiki on Drifting:
Drift tuning Drive train A proper mechanical limited slip differential (LSD) is almost considered essential for drifting. Attempting to drift with an open or viscous differential in a sustained slide generally yields relatively less impressive results. All other modifications are secondary to the LSD. The preferred form of LSD for drifting is the clutch type, in "2-way" form, for its consistent and aggressive lockup behavior under all conditions (acceleration and deceleration). Some drift cars use a spool "differential", which actually has no differential action at all - the wheels are locked to each other. Budget-minded drifters may use a welded differential, where the side gears are welded to give the same effect as a spool. This makes it easier to break rear traction because it reduces maximum traction in all situations except traveling in a straight line. Welded differentials have an inherent risk involved, due to the tremendous amounts of internal stress the welds may fail and the differential completely locks up leaving the rear wheels immobilized. Helical torque sensing types such as the Torsen or Quaife (available on cars in certain stock trims such as S15, FD3S, MX-5, JZA8x, UZZ3x) differentials are also adequate. The clutches on drift cars tend to be very tough ceramic brass button or multiple-plate varieties, for durability, as well as to allow rapid "clutch kick" techniques to upset the balance of the car. Gearbox and engine mounts are often replaced with urethane or aluminum mounts, and dampers added to control the violent motion of the engine/gearbox under these conditions. Gearsets may be replaced with closer ratios to keep the engine in the power band. These may be coarser dog engagement straight cut gears instead of synchronised helical gears, for durability and faster shifting at the expense of noise and refinement. Wealthier drifters may use sequential gearboxes to make gear selection easier/faster, while sequential shift lever adapters can be used to make shifts easier without increasing shift time.
07-29-2013, 08:51 PM | #12 |
Too much is never enough
655
Rep 3,079
I'm in a very similar boat, sort of. I have a blown '07 GT putting down around 600. I also have a 335i. It's a completely different experience in that the BMW does everything you ask it to very, very well with little drama. My Mustang does too, but it's nowhere near stock. The difference is that I don't feel like Bruce Lee used my kidneys as a punching bag after driving the BMW. The classic BMW weight distribution and brake balance is so good you'll never look back. I still love the Mustang for days when I'm in the mood for a hammer. The BMWs are for days when I prefer a scalpel.
Ironically, my Mustang was my daily driver for the last 5 years. It's hardly a good car for someone hauling clients around, but every last one of my clients is disappointed if I DON'T bring it by every once in a while and take them for a ride. |
07-29-2013, 08:51 PM | #13 |
1112
Rep 12,740
That's it I'm sold on the LSD. I think I'm gonna pull the trigger soon- sounds like the last thing I need performance wise to round things off!
07-29-2013, 09:00 PM | #15 | |
86
Rep 1,849
I'd say the biggest downsides to the ediff we have is that it can cook the rear brakes more quickly than otherwise, wear down the rear brakes way more quickly than otherwise, and can warp the rotors given enough sustained high performance driving (I can attest to the last two as I've had the rears replaced twice now and my rear rotors warped once). Edit: And I surmise an e-diff probably has slightly (but only slightly) greater losses of energy to friction than an LSD. Also, installing an LSD will not turn off the e-diff. It can't be turned off, afaik. It won't be intrusive once an LSD is installed, though, and will only kick in under more extreme conditions. Read that first link I posted in this thread about e diffs for much more detailed info.
07-29-2013, 09:12 PM | #18 |
2030
Rep 2,672
I have Quaife LSD and it is the best mod for this car. Completely silent and very reliable. edif sucks balls especially on track. It kills the throttle and you are constantly fighting the car instead of learning how to properly modulate the throttle and steer properly. I turn traction nanny off completely. BMW made a huge mistake of not offering LSD as an option. e9x can't put power down without LSD, no question about it. It is also amazing during winter with snows.
07-29-2013, 09:15 PM | #19 | |
170
Rep 1,843
There was a later update to CIC which brought more functionality, I think 2011 or 2012? not sure, my car is a 2009. One of the things that gets you is ability to stream music over Bluetooth and also more online stuff but honestly I don't miss either. Maybe if I'd had it I would think differently but at least the BT streaming seems gimmicky to me, I have it in my Jeep (aftermarket JVC head unit) and I can tell the difference in sound quality between the exact same files played through my phone over BT and played off a thumb drive to the USB input. Maybe BMW does it better? haven't tried it... |
07-29-2013, 09:16 PM | #20 | ||
Rep 10
To put my question in simpler terms, can i do short basic powerslides with a 325i(v6 one)? |
07-29-2013, 09:17 PM | #21 | |
Rep 10
07-29-2013, 09:23 PM | #22 |
89
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
