Full Tune Up
07-29-2013, 01:38 PM | #1 |
165
Rep 560
Full Tune Up
I'm approaching 85000 miles on my 328xi and am considering doing a full tune up a little early. I know sparks and filters should all get changed anything else?
07-29-2013, 03:50 PM | #4 |
964
Rep 3,854
Drives: 330i, 135i
Brake, power steering and radiator fluids never hurt to change. Add these to your Tune up list if you can...
07-29-2013, 04:35 PM | #5 |
295
Rep 2,202
Coils. Engine oil. Alignment. Check your bushings struts etc. look for leaks around the engine. Common gaskets are oil filter housing and valve cover. Probably get a clean with some Techron fuel cleaner. Never tried it myself but some here say it works.
I did a coolant flush for piece of mind. Are you planning on a DIY with this tune up or take it to mechanic?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-29-2013, 04:42 PM | #6 |
89
Rep 3,732
Drives: BMW S1000XR
^^^ all the above and consider ATF and the following parts if not replaced already:
water pump & thermostat fuel filter tensioner pulley serpentine belt radiator O2 sensors
BMWCCA member |
07-29-2013, 07:01 PM | #7 | ||
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
07-29-2013, 08:32 PM | #8 |
17309
Rep 18,733
I don't think it was a smart ass comment to suggest reading the manufacturer's literature about service and maintenance information, but:
100,000 Miles: Spark Plugs Engine air filter coolant change transmission oil/fluid change front and/or rear differential gear oil change Inspect wiper blades and replace if necessary Engine oil change if called for by CBS Replace cabin air filter if CBS calls for it Flush brake fluid if called for by the CBS (2-year intervals) Chassis inspection - lube locks, hinges, door weather seals Check for wheel bearing play Check for torn CV joint boots Check for leaking shocks Check for missing/broken chassis components Flush power steering fluid if you want (not a required maintenance item) |
07-30-2013, 06:49 PM | #9 | |
49
Rep 223
For a brake fluid change, how many ounces of new fluid do you need? I can't find the correct amount in the bentley manual... |
07-30-2013, 07:03 PM | #10 | |
964
Rep 3,854
Drives: 330i, 135i
coolant change transmission oil/fluid change front and/or rear differential gear oil change Courious how much the stealership would charge me for something like this... |
07-31-2013, 05:31 AM | #11 |
17309
Rep 18,733
If you do it correctly and don't let air get in the system through the master cylinder you only need a 32 ounce bottle, and you'll have plenty left over. If you are doing a bleed for the first time, get a 32 ounce bottle and a 16 ounce bottle to be on the safe side. Keep the 16 ounce bottle unopened and it will be good for the next change two years from now.
