07-26-2013, 09:29 PM | #1 |
12
Rep 46
motor mount shot
unfortunately my f30 320i passenger side motor mount is shot and gonna be replaced by dealer under warranty, just 7500 miles.
somehow i remember motor mounts must be replaced by pair? am i right? |
07-27-2013, 09:17 PM | #2 |
Too much is never enough
655
Rep 3,079
Nah. No real rational reason for replacing them in pairs. If it needs one already, it was defective from day one. The others should be fine.
08-23-2013, 09:02 PM | #3 |
12
Rep 46
Guess what, replaced my passenger side motor mount a month's ago and now noise from driver side motor mount, just got back dealer and they will replace it under warranty again, but, how is this possible? Drove it for only 6 months, delivered on 02/13, manufactured on 08/12. 8k miles on it.
08-28-2013, 04:18 PM | #4 | |
8
Rep 158
2013 320i, 6sp Manual, Sport Package / 2003 M3 track car
08-28-2013, 05:43 PM | #5 |
104
Rep 1,715
08-28-2013, 07:49 PM | #6 |
12
Rep 46
turn off everything in cabin, shift between drive and reverse(doesn't matter if the brake is applied), when the car is making slight movement, a squeaky noise comes from firewall area.
08-29-2013, 01:00 PM | #9 |
8
Rep 158
Interesting. In some cars, broken engine mounts lead to coolant hoses and the fans getting together when the engine moves. Sounds like you issue was much more subtle, luckily.
08-29-2013, 02:25 PM | #10 |
413
Rep 1,975
I have a similar symptom... I thought it was the steering wheel. I'll have to look into this.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
07-07-2018, 06:19 PM | #12 |
601
Rep 1,048
Going back to earlier statement that they don't need to be replaced in pairs. If one fails and is not replaced immediately, the vibration can damage the other two. If one fails and it takes a while to diagnose, I replace all 3.
07-07-2018, 07:50 PM | #13 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Had one fail on one BMW car, 2014 435 @ 35K miles. Never happened before or after on any BMW I had. Poor part QA?
Only other mount failure I had in about 60 years of driving was on a 1962 409/409 4MT Impala. Can't imagine why that happened. I would check the other two but I it was caught right away a single replacement should be good to go.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
07-08-2018, 04:47 AM | #14 | |
12
Rep 79
Either it must be reall bad quality, or something is hurting the mounts. However, they just replaced the front engine mount. I´ve heart, there might be a third mount?? Edit: car has only 22t km, 14t miles on it. |
07-08-2018, 12:18 PM | #15 | |
3127
Rep 5,264
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 07-08-2018 at 12:31 PM.. |
07-08-2018, 03:16 PM | #16 |
601
Rep 1,048
There is a rear mount under the transmission behind the spot the engine is bolted onto the bell housing. If they fail that fast, something must be wrong to cause excessive vibration (timing???). A motor mount is not complicated - a piece of very hard rubber (or some plastic equivalent), and attachment points on the top and bottom.
07-08-2018, 08:51 PM | #18 |
Rep 1
I understand the motor mounts are designed to shear as a safety feature in the event of a collision.
I had a squeak under the hood that the dealer could not pinpoint for 2 years. Whenever I brought the car in for service they tried unsuccessfully to isolate. (Irritating squeak or rattle at idle - 2 liter diesel kind of rough idle to start with). Finally problem was identified as a broken motor mount. They only replaced one. That’s when I researched and found the mounts are designed to break/shear for safety reasons and they actually fail quite often. I suspect due to bumpy roads - possibly extreme breaking? Lots of potholes here in boston. |
12-26-2018, 10:08 PM | #20 |
88
Rep 69
Anyone attempt this by themselves? I had issues with my exhaust rattling and more recently the air intake breaking a clamp, suspect engine movement due to a bad mount. have over 165K miles and think it is time to swap all (3) mounts. But would love to see a video of how to do it on my '14 320i xDrive...
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
12-27-2018, 09:08 AM | #22 | |
88
Rep 69
Thanks for the reminder.
