Hmm, is this noise from the turbo or the clutch :(
07-25-2013, 05:29 PM | #4 |
86
Rep 1,849
Sometimes, I get a similar noise when I turn my car off. I drive an a/t.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
07-25-2013, 06:08 PM | #6 |
129
Rep 483
07-25-2013, 06:09 PM | #7 |
129
Rep 483
07-25-2013, 06:25 PM | #8 | |
Rep 52
I had a noise like yours but it wasn't as loud and it was coming from the rear...brought it in and they changed the exhaust caps |
07-25-2013, 09:51 PM | #9 |
158
Rep 3,158
I remember some years ago on this forum, someone else had the exact same sound, posted a video of it. If I recall, I had thought it was the direct injectors (and perfectly normal), but someone else came in and mentioned it was something else. Damn, I can't remember what they said it was, but I do remember it's quite safe and normal.
BTW, I get the same sound (rattling sound on engine-off); 6 MT here. EDIT: Let me try to search through some of my old (early) threads....
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
07-25-2013, 09:57 PM | #10 |
158
Rep 3,158
Okay, back from a quick tour down memory lane here.
Turn the engine off while holding the clutch in. If the noise goes away, it's the infamous manual tranny "death rattle" (ironically named: it's okay). If the sound is still there.....well.....
--Mark Twain |
07-25-2013, 10:18 PM | #11 |
1045
Rep 5,660
I somewhat resembles the turbo waste gate (TWG) rattle. Does it only exist when the car is cold started and during the first few minutes of running after a cold start? If so, I'd say it TWG rattle.
Sadly, given the quality of the recording, that sound might resemble any number of things. I'd at have an expert definitively ascertain the true cause. Once I knew what it is, I'd then decide what, if anything I'd do about it.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-26-2013, 08:10 AM | #12 |
129
Rep 483
but how about flywheel... It connects to the engine
07-26-2013, 10:01 AM | #13 |
158
Rep 3,158
Well, if you do what I suggested and the noise goes away with the clutch pedal pushed in, then the noise is from the dual-mass flywheel.
I've read that this is a common....feature....of many different brands of cars that have manual transmissions and dual-mass flywheels. Nothing to be worried about.
--Mark Twain |
07-26-2013, 11:27 AM | #14 | |
129
Rep 483
07-26-2013, 01:06 PM | #15 |
158
Rep 3,158
Ha! You have a 335; you'll have other things to worry about on the track (i.e. limp mode overheating).
--Mark Twain |
07-26-2013, 01:40 PM | #16 |
124
Rep 1,362
This... Do what galahad05 said, press in the clutch pedal while shutting off the engine and if it doesn't make that sound it's the dual mass flywheel and it totally normal. I've got used to shutting off the car like this as my car made this noise since new.
07-26-2013, 02:02 PM | #17 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Pretty sure this sound is normal when shutting it off with the clutch out. Mine has always done this when I turn it off in neutral with the clutch out. But when I have the clutch in (almost always) it doesn't make that noise. If yours doesn't make it when your clutch is in then you're fine.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
07-26-2013, 02:04 PM | #18 |
26
Rep 336
Sounds perfectly normal for an MT car. My E46 made the same noise if I shut it off with the clutch out, same with my Jeep Wrangler and my E90. I don't think you have anything to worry about, but if the noise bothers you then just make sure you have the clutch depressed when you switch off the car.
