Ebrake disconnects by itself?
07-25-2013, 09:22 AM | #1 |
83
Rep 1,093
Hi guys,
I got a e90 lci steptronic, today when i was at a traffic signal i left the car in "N" (neutral) & pulled the Handbrake since it was a long signal, once the signal went green i just shifter the Gear to "D"(Drive) without disengaging the Ebrake. I drove few meters ahead & then the car popped up the "P brake" sign & kept making the Bong sound but i didn't feel any resistance from the ebrake, so wanted to know does it switch off auto or i didn't feel must resistance cause our cars are rwds? I know the e90 has manual handbrake so this surprised me. Thanks.. |
07-25-2013, 09:49 AM | #2 |
just another bmw douche bag
195
Rep 3,640
it doesn't switch it off, the ebrake just wasn't engaged super tight when you drove off. The e brakes are small, so it doesn't take much to overpower it, unless it's really cranked down (or you are going in reverse).
So you were just wearing out the brake shoes for a bit. |
07-25-2013, 09:55 AM | #3 | |
18
Rep 188
09' e92 Montego Blue back to stock...for now
07-25-2013, 10:03 AM | #4 | |
83
Rep 1,093
Not at all, was impulsive & feel sad it happened now |
07-25-2013, 10:59 AM | #6 |
124
Rep 5,627
07-25-2013, 11:24 AM | #7 | ||
83
Rep 1,093
well i got this car used, any idea when the E brake drums are replaced in miles? Thanks guys |
07-25-2013, 11:25 AM | #8 | |
72
Rep 436
p.s. I think you were trying to pose and you got caught up...just saying. |
07-25-2013, 11:26 AM | #9 |
81
Rep 6,092
hahahah happens to me like once every couple months. i forget to put the ebrake down and drive a few feet, then the dash lights up and bongs away like a party.
btw, putting it in neutral at a stoplight with an auto is completely useless. just leave the damn thing in D. you dont have a stick.
07-25-2013, 11:44 AM | #10 |
26
Rep 606
No way to check if they are worn. Best test is to have someone in the car ready for a roll, park it on a steep hill, put it in park and pull the e-brake, have someone try and push the car downhill. If it squeals and moves then it may be a bit too worn for comfort. It's pretty unlikely they are that worn out though. I just replaced all the e-brake parts recently and mine looked mostly fine after 70k miles and didn't really need to be changed. It may also just need to be adjusted so it'll tighten up with less lift of the e-brake handle.
07-25-2013, 12:27 PM | #12 | |
83
Rep 1,093
Thanks.. |
07-25-2013, 12:45 PM | #13 |
81
Rep 6,092
take it to an indy shop. my guy re-adjusted my ebrake in like 30 min.
07-25-2013, 01:07 PM | #14 |
148
Rep 1,100
I used to do that too....
when I was in high school! Not trying to bash you or anything, but seriously, what is the point in leaving it in neutral and using the handbrake? What and who are you trying to prove? Like hailpersia said, might have been a lot less work to just keep your foot on the brakes. and if it was reallllly that long of a wait, then you just should have shut down the car.
2010 335i Coupe- Monaco Blue Metallic
07-25-2013, 09:18 PM | #16 |
195
Rep 3,640
07-25-2013, 09:21 PM | #17 | |
72
Rep 436
07-26-2013, 12:19 AM | #18 |
Where'd my VTEC go?
481
Rep 6,067
the ebrake doesnt really get worn out unless you make it a habit of driving with it up all the time.
and +1 to no use in using neutral + ebrake for an auto.
07-26-2013, 03:55 AM | #19 |
83
Rep 1,093
thanks for the info guys, i switch from"D" to "N" in signals cause i feel leaving it on Drive & keepign the brakes pressed in signals wears the rear brake pads & heats up the gearbox?
am i right? Thanks.. |
