Vacuum hose inner diameter for 335i various applications
07-24-2013, 02:31 PM | #1 |
174
Rep 532
Hey gang - I've searched and see different replies.
What is the correct inner diameter hose for the OEM BMW vac hoses under the hood on a 335i N54 (2007). It's 3.0 (inner diameter), right? I ask because ECS shows it as 3.5 on a few diagrams, other people say 2.5 on the forums. I want to repalce with exactly stock which I believe is BMW PN 51711470035 (for 1 meter of the stuff) THANKS THANKS |
07-24-2013, 03:51 PM | #2 |
General Nuisance
25
Rep 277
Get some turbosmart 3mm silicone hoses, you'll be good to go. The stock ones deteriorate rapidly and are not suitable for the application. This is a known source of boost leaks. For areas near the turbos, the line seems to have some kind of insulation however, so i'd look into insulating any lines near the turbos.
'07 E92 335i 6MT
Full Bolt On's, Vargas Stage 2's, Carbon Fiber, and Methanol. |
