Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      07-24-2013, 01:35 AM   #1
swamp2
swamp2's Avatar
Drives: E92 M3
Lightbulb BMW M3/M4 s55 Engine RPM Redline Projections via Technical Sound Analysis
BIMMERPOST
     Featured on BIMMERPOST.com
Originally Posted by ProbyOne View Post
Check out the video at 3:07
1. Try to match the frequency of the observed sound which I estimate is around 350 Hz.
2. Figure out the speed of the car away from camera. It sounds like the top of 3rd gear which should be around 90-100 mph depending on gearing.
3. Correct for Doppler effect. Easy if you can Google. http://www.wolframalpha.com/input/?i...400Hz%2C+90mph
So again, it sounds pretty close to 8000 rpm. It's way better than a guess.
Fantastic idea! Taking your lead I dove in head first.
I began testing a couple of dyno recordings and fairly quickly found an E92 M3 video and V12 Aston with 6800 rpm redline. I recorded the sounds (just from crappy Youtube videos) and then did a Fourier transform to get the spectral content. E92 M3 frequency peak at redline should be 560 Hz, I measured 570 Hz. V12 Aston is 680 Hz theoretical, 688 observed. In both cases "the" peak was actually the second peak not the first. Those results are within about 2%. The method absolutely can work.
Moving on the the M4 video I'm not entirely sure that around the 3:07 time mark he get's a true redline shift. I think this is at Galgenkopf, what do you think? Based on that he is indeed most likely in 3rd and I agree that the peak speed at redline should be around 90-97 mph (depending both on gearing and redline). Getting a true discernible peak in the spectral results was not straight forward as compared to the dyno runs (to be expected) and thus my results are a range of frequencies from 345-365 Hz. The capture below from ~5.5-6.0 seconds is showing a discernible (first) peak at 358 Hz. Combining that with the Doppler effect from 90-97 mph gives a source frequency in the range of about 385 - 415 Hz. That in turn translates to 7700-8300 rpm! This is entirely consistent with my prior estimate of a peak redline of 7700 rpm.
UPDATE 7/26: Thanks to some additional insights from post below by bradleyland I am revising my final rpm estimate down considerably to 7250-7550 rpm. In short my audio capture was too low in quality. I did recheck a couple cases of dynos mentioned above using the new technique. For instance the V12 Aston came in at 6770 vs. 6800 quoted, less than 0.5% difference.
Given the F10 M5s redline in particular, 7200 rpm, I just don't think 8000 (Admin edit: rumor is close to 8000 rpm) is possible. There is also the prior problem of resolving the inconsistency of an 8000 rpm redline, about 400 ft lb of torque and about the same power as the existing M3...
To be more accurate and more certain we need a video of a clear redline shift with good audio quality and minimal Doppler (i.e. camera right by shift point). Anyone?
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      07-24-2013, 06:06 AM   #2
neo871
neo871's Avatar
Romania
142
Drives: 340i xDrive MPPSK
Thumbs up M3/M4 s55 Engine Redline Projections from Technical Sound Analysis
This is impressive! What do you actually do for a living?
      07-24-2013, 07:12 AM   #3
CanAutM3
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
Great work, as usual Swamp .
Now we only need a clean vid to remove some of the variability
      07-24-2013, 07:26 AM   #4
mkoesel
Moderator
Drives: No BMW for now
Swamp, if you were my professor I would love your lectures but loathe your exams. That's very impressive work - gotta give props to both you and the guy that suggested the idea. I'll be even more impressed if your numbers match the production engine.
I wonder if the engine sounds from development-M5 track footage consistently yield 7200RPM. It would be an example (or examples) that are close to home.
      07-24-2013, 11:02 AM   #5
swamp2
swamp2's Avatar
Drives: E92 M3
I wonder if the engine sounds from development-M5 track footage condisently yield 7200RPM. It would be an example (or examples) that are close to home.
Thanks. I wanted to do some more work using actual track clips but did not have the chance. If you can suggest a good, clear redline occurrence for the F10 M5 I would be happy to repeat the analysis. It very quick to do actually, the software does everything.
      07-24-2013, 08:03 PM   #6
duk
///M
Drives: 2011 AW/FR 6MT E92
if it's 8k redline omggg take my monies? lol
2011.5 AW/FR E92 M3 6MT
      07-24-2013, 08:23 PM   #7
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
I agree making this engine have a 8k redline will make it closer to true M engine.
      07-24-2013, 08:45 PM   #8
Mangler
Mangler's Avatar
15
Drives: 08' 335i, ZHP 330i
88 .  [0.00]
2008 BMW 335i  [0.00]
I have a go pro video from the front number of the new m6 driven to redline on a track if it would help.
T
      07-25-2013, 02:07 AM   #9
swamp2
swamp2's Avatar
Drives: E92 M3
T
Thanks, might be fine to try but I'd prefer something a bit closer to a spectator filmed one like the video the analysis is based on.
      07-25-2013, 02:08 AM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
I'm a recovering physicist and recovering engineer. Now I sell engineering software.
      07-25-2013, 12:02 PM   #11
aajami
aajami's Avatar
Drives: Space Gray '09 E92 M3
Big props to you Swamp. I'll be curious to see how accurate your projections are once the car is officially unveiled.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      07-25-2013, 12:56 PM   #12
Brosef
Brosef's Avatar
Drives: F90 M5
this is why I read Bimmerpost. awesome analysis as always.
      07-25-2013, 01:08 PM   #13
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
I'm no expert in this field, but aren't there still a number of unknowns you'd need to know before making these calculations? I see you make an estimate on speed, but wouldn't gearing and exhaust acoustics also come into play? Also, it's probably a safe assumption, but still an assumption that the car is shifting at redline.
Excellent analysis though.
      07-25-2013, 01:53 PM   #14
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Wow! Great work. Look forward to seeing the comparison between your analysis on the production S55.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      07-25-2013, 02:03 PM   #15
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Great job!
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      07-25-2013, 02:25 PM   #16
///Matthew
///Matthew's Avatar
196
Drives: 2013 M3, 1999 M3
Very impressive! Thank you!
2013 Santorini Blue M3
1999 Estoril Blue M3
mfatuation.com
      07-25-2013, 02:30 PM   #17
e1000
that's what SHE said!
75
Drives: 2011 E92 M3 ZCP
He stayed at a Holiday Inn Express last night
      07-25-2013, 02:31 PM   #18
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
Doppler effect is one of my favorite physics topics, explaining so much in the real world.
Cool stuff!!
      07-25-2013, 02:45 PM   #19
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Dang-it you beat me toooo it!
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      07-25-2013, 02:55 PM   #20
solstice
5457
Drives: 2015 M3 6MT
Nice!
Here's a pretty clean audio of the only production I6 turbo M car, it's in cabin but it would be interresting to see what top rpm the SW spits out.
4:24 and 4:28 for example seems like possible redline shifts.
( if you watch the whole thing you will also see two M3s showing who the daddy is )
      07-25-2013, 02:58 PM   #21
bimmerjph
bimmerjph's Avatar
Drives: 2005 Z4 3.0
That is actually quite impressive.
Good work!
      07-25-2013, 02:58 PM   #22
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
I want to say ,realistically, it's more like 7500 rpm.
Tags
2014 bmw m3, 2014 m3, 2014 m3 forum, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m4, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, f80, f80 forum, f80 forums, f80 m3, f80 m3 forum, f80 m3 forums, f80 m3 sedan, f82, f82 coupe, f82 forum, f82 forums, f82 m3, f82 m3 coupe, f82 m3 forum, f82 m4, f82 m4 coupe, f82 m4 forum, f82 m4 forums, f83 m3, f83 m4, m forum, m forums, m3 f80, m3 f80 forum, m3 f80 forums, m4 forum, m4 forums
f80post
