Major Service Issue - Fuel Injectors / No Warranty...does recall apply?
07-23-2013, 02:54 PM | #1 |
El Capitán
521
Rep 2,652
So I just got a call from my local dealership...
Took my car in for it to be checked out as I was having issues running. The car felt like it had a bad HPFP and I scanned it over the weekend with a friends COBB. Got four codes: Golf Tee Mod Mixture Control Mixture Control Possible Fuel Pump Failure Cleared the codes...drove around for a minute and got all three codes back minus the Possible Fuel Pump Failure - figured it'll come back again. So I figured I'd take it in to get serviced - I scanned it before because I am 3 months out of warranty and wanted to make sure I wasn't getting myself into some shit. Well I'm in some shit. Just got a call...no trace of a bad HPFP but it seems my injectors are bad. The cost you ask>>> $2,700. FML So I come on here...look around and notice there was a recall for injectors: http://www.e90post.com/forums/showpo...&postcount=519 ^^^3rd attachment I immediately look up my vin on REALOEM.com and see my production date was 08/2008 - which is within the 04/02/2007-10/31/2008 window. Would this still apply to me? How long is this recall good for? Any insight would be great...I'm bumming out pretty bad and need some feedback |
07-23-2013, 02:56 PM | #2 |
814
Rep 3,953
If this was already done to your car, than it is not covered a second time.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
07-23-2013, 03:00 PM | #3 | |
El Capitán
521
Rep 2,652
Let's pretend for a minute - If it was NOT done...does this recall still apply? Would I be able to leverage them into honoring it? Don't know how I would leverage them as they have my balls in their palm...but I can try... |
07-23-2013, 03:05 PM | #4 |
19
Rep 345
Drives: '08 335i, '03 Kawa Z1000
Find out if they were ever done before. Also, I might be wrong, but that sounds like a pretty steep price. Shop around for the parts and get a quote from an indy to install.
07-23-2013, 03:09 PM | #5 | |
19
Rep 345
Edit: On a side note, my injectors were done under the recall two years ago. They all needed to be replaced again a month ago. Luckily they were covered under CPO this time, but the point is there are known issues with this part. Despite missing the recall originally, they should give you the benefit now if they were never done. |
07-23-2013, 03:16 PM | #6 |
El Capitán
521
Rep 2,652
Not the first owner...but purchased the car back in August 2011. The recall was announced December 2010. Don't know if it was already done...but I can definitely ask.
07-23-2013, 03:21 PM | #7 |
58
Rep 494
Give them the recall #, some dealerships do not even check for that. And if they do say that it was replaced ask for written proof as if warranty / recall work was done they should have it on file.
07-23-2013, 03:21 PM | #8 |
319
Rep 1,023
Injectors are a pretty easy DIY, if you can do that sort of thing. Worst part is the new p/n that just came out which are about $200 per injector.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
07-23-2013, 03:28 PM | #9 |
27
Rep 172
07-23-2013, 03:40 PM | #10 |
El Capitán
521
Rep 2,652
07-23-2013, 03:42 PM | #11 |
58
Rep 494
07-23-2013, 03:44 PM | #12 |
El Capitán
521
Rep 2,652
It was replaced March 2011...and I don't know who replaced it - I didn't have the car. I'm guessing it was the previous owner who took it in.
07-23-2013, 03:47 PM | #13 |
58
Rep 494
I believe your service history should show this and most dealerships will give you that for free. Maybe call your nearest dealer and ask? Also, I'm not sure if it matters, but I wonder if they replaced injectors with the correct ones (I believe updated version).
07-23-2013, 03:49 PM | #14 |
El Capitán
521
Rep 2,652
Just asked. They were replaced under warranty...but even the current ones installed on my car aren't as NEW as the ones they'd replace them with. So technically...the recall wouldn't count for my car.
07-23-2013, 03:49 PM | #15 |
19
Rep 345
I think the warranty on this type of work is one year, not two. Sorry op. look into getting the parts yourself and having independent do the work.
07-23-2013, 03:53 PM | #16 |
52
Rep 307
I recently found a local shop who is run by ex-Fields mechanic. Give him a call, 407-375-5547 his name is Ghani. I never used him but got a quote from him recently which was 50% below what fields quoted me.
07-23-2013, 03:56 PM | #17 | |
58
Rep 494
If all else fails, get parts yourself and go to a good indy and that should save you quite a lot. I've found some injectors on rockauto.com but I do not have any experience with them (they are about $100 each). |
07-23-2013, 04:24 PM | #18 |
Rep 22
FWIW I've read that Techron fuel injector cleaner works wonders for these cars. If it was my car I'd try a couple of bottles of that first to see if the injectors just need to be cleaned.
07-23-2013, 04:42 PM | #19 | |
319
Rep 1,023
In any case, looks like there's no getting someone else to pay for it at this point. If they really are the culprit, I guess it's $2700 or do it yourself!
07-23-2013, 05:44 PM | #20 |
Beamer Mantic
82
Rep 1,191
So new replacement FI only last a few years? That's crap if I must say so, I would be quite frustrated with the $2700!
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
07-23-2013, 06:41 PM | #21 |
14
Rep 1,044
07-23-2013, 07:21 PM | #22 | |
129
Rep 820
other than that here is the diy for injector replacement http://www.***********.com/showthrea...ector-swap-DIY but try the cheapest solution first, use some techron (3/4 of the bottle with a full tank) i usually do it every 5000 miles. if that doesnt work you will have to buy the injector which is approx 130$/eachx6=780 +/- and not 2700!!!! |
