Turn off turn signal when unlocking car?
07-23-2013, 02:35 AM | #1 |
63
Rep 294
What title says, You know when you unlock your car both turn signals blink as you unlock your car. Anyone know how to turn that off. I find it annoying. I just want a straight up unlock my car. dont need no fancy lights to notify me that my cars unlock. Thanks
07-23-2013, 02:53 AM | #2 |
52
Rep 204
Have you gone through your car computer via either the turn signal stalk or maybe in your IDrive? There are different behaviors you can set when you lock/unlock your car. Also recommend you check your manual for exact specifics. It's laid out definitively in there.
Good luck.
20% Tint | Matte Black grilles | Beyern Spartan 20" Wheels Hyper Silver | Toyo 245/35/20R | ACS springs
07-23-2013, 02:19 PM | #3 |
164
Rep 401
I don't remember off the top of my head if this is available in your normal settings through your dash/i-drive, but if not I know it can be eliminated through coding. Easy to do once you obtain the proper cable and software. Hardest part is getting the software set up and working correctly, but once set up the actual coding process is extemely quick and easy
07-23-2013, 07:33 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
It's an option on the BC stalk and/or iDrive.
