F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > coding help me
Studio RSR
      07-22-2013, 08:03 AM   #1
thebadboy
19
Drives: 335i f30
coding help me
hello,
I live in Belgium and my English is not good, so I translated with google, sorry.
I am newbie in the coding and a problem.
I have cable and ESYS_v.3.18.4 and v.48.2_SPdZ.
I followed the procedure pdf Part 1 only on step 11 it goes wrong,I select the CADF line, then "Read Data Coding", he writes error, so that 's right, but I do not have a new folder that appears as point 13 pdf
what is the problem
please help me
pdf part 1==> http://www.f30post.com/forums/showpo...71&postcount=1
Uploaded with ImageShack.us
      07-22-2013, 08:43 AM   #2
Scottdee
Drives: 2010 520Se Touring, Sports pkg
Right click?
      07-22-2013, 08:50 AM   #3
thebadboy
19
Drives: 335i f30
Originally Posted by Scottdee View Post
Right click?
right click
it does not go, there is no new folder that appears.
I block between step 11 and 13 of pdf.
it must read data encoding all CAFD icon?
thank you
      07-22-2013, 01:12 PM   #4
thebadboy
19
Drives: 335i f30
I managed to read the data encoding, but not all and I do not know why.
Then when I made ​​a right and "edit fdl" click it asks me for a pass word.
what is the pass word
thank you
      07-22-2013, 04:55 PM   #5
thebadboy
19
Drives: 335i f30
up please
      07-23-2013, 05:34 AM   #6
HFW003
HFW003's Avatar
Australia
5685
Drives: 2024 M340i xdrive
Originally Posted by thebadboy View Post
I
This is the soft token you must purchase.
I don't have the details of where to purchase with me but I'm sure someone else can post here for you.
Good luck
H
      07-23-2013, 06:07 AM   #7
thebadboy
19
Drives: 335i f30
Good luck
H
I was told that the token was available on the internet for this version of ESYS_v.3.18.4, but I do not find them.
who can give me please
      07-23-2013, 06:27 AM   #8
HFW003
HFW003's Avatar
Australia
5685
If it is the latest version you cannot get it for free.
      07-23-2013, 06:30 AM   #9
thebadboy
19
Drives: 335i f30
ESYS_v.3.18.4 is not the latest version but I can not find the token yet they are free user
      07-23-2013, 07:38 AM   #10
HFW003
HFW003's Avatar
Australia
5685
Try 2690.
      07-23-2013, 07:54 AM   #11
thebadboy
19
Drives: 335i f30
Try 2690.
is the token,
thank you
      07-23-2013, 07:55 AM   #12
HFW003
HFW003's Avatar
Australia
5685
You're welcome.
      07-23-2013, 09:24 AM   #13
thebadboy
19
Drives: 335i f30
one more question,
here is what is written in pdf ==>Step 13: New option under CADF, a folder. Expand the folder by clicking + and right click that file, Select “EDIT FDL
but I'm sure it will CAFD file when I made ​​the manipulation does not create a new folder.
why?
      07-24-2013, 12:18 AM   #14
HFW003
HFW003's Avatar
Australia
5685
Im not exactly sure what you mean?
The picture you have in post #4 from what I can see IS step 13. The blue CAFD highlighted is what you are going to code.
Once you have inputted the token it "should" take you to the actual ECU you need to change the Werte values, which is step 14.
Good luck
H
      07-24-2013, 01:23 AM   #15
thebadboy
19
Drives: 335i f30
not easy to understand with google translation
The problem is that the step 11-12 and 13 it does not work for all file CAFD
      07-24-2013, 02:24 AM   #16
HFW003
HFW003's Avatar
Australia
5685
You don't need to do it for all CAFD's?
You only do it for those you want to change.
For example, you would probably only need to use the Fem body, ACSM, HU CIC/NBT, Kombi and REM ECU modules, therefore you don't need to touch the other CAFD files listed.
In the pic #4 above you have highlighted the AMP module. I don't even know what that does and it's certainly not something I ,or anyone I know of, has needed to change.
Hope that helps mate.
H
      07-24-2013, 07:03 AM   #17
thebadboy
19
Drives: 335i f30
thank you very much, your answer really helps.
I found the cheat sheet for f30, how to know is to make the change.
eg I would like to activate the drive connected, or that it is you
this is what I aimerasi coding
- Enable beep opening and closing car
-enabled camera rolling
-activate video in motion
-to the sound of the alarm type U.S.
-display speed
-display tire pressure
etc.
know how or because it is on the cheat sheet there is no information of where it is.
https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0
really thank you because without your help I would not get there
      07-24-2013, 07:26 AM   #18
HFW003
HFW003's Avatar
Australia
5685
Sorry, Google translator has really made a mess of what you said.
Here are other cheat sheets which I think might contain some of the things you are after, such as the individual tyre pressures and digital speedo.
http://www.f30post.com/forums/attach...1&d=1371060638
http://www.bimmerfest.com/forums/att...9&d=1339114795
Good luck.
      07-24-2013, 08:30 AM   #19
thebadboy
19
Drives: 335i f30
thank you for my cheat sheets. I'm looking for how to enable the drive connected, the cheat sheets there is no coding for connected drive
      07-24-2013, 04:19 PM   #20
HFW003
HFW003's Avatar
Australia
5685
Sorry mate, I am unsure exactly what you mean.
      07-24-2013, 06:00 PM   #21
thebadboy
19
Drives: 335i f30
how to activate connecteddrive
      07-24-2013, 06:05 PM   #22
HFW003
HFW003's Avatar
Australia
5685
Sorry mate, I cant help you with that one.
Suggest sending shawnsheridan a PM and ask him. If anyone knows, he will!
Be safe.
f30post
