help with check engine code
07-19-2013, 12:12 PM | #1 |
285
Rep 2,146
Drives: F80 M3
Hi guys I was pulling out of my garage last night when i got the dreaded half engine yellow light, when I used the stalk to check the code it came up with cc-id 29 I also had cc-id 97 previously. I know that 29 is a dme fault and that 97 is an airbag fault. My main question is, I am currently under extended warranty and when I restarted the vehicle the light was no longer on. Will the DME log the code? I would like to take my car to the dealership so they can resolve this but do not want to waste my time if they cannot see the error code.
Instagram: http://instagram.com/e90nate
07-19-2013, 12:18 PM | #2 |
37
Rep 433
Drives: 335i wagon, Pure Stage 2+PI...
Dunno for sure about your prob. But you haven't written what tune your running, if any, and if your not then this is the wrong section to post. Good luck
07-19-2013, 12:31 PM | #4 |
285
Rep 2,146
Drives: F80 M3
sorry guys i must have posted in the wrong section, i am not running a tune.
07-19-2013, 05:17 PM | #5 |
161
Rep 7,377
Google the code...
07-19-2013, 09:21 PM | #6 |
285
Rep 2,146
Drives: F80 M3
07-20-2013, 08:38 AM | #7 |
37
Rep 433
07-20-2013, 12:57 PM | #8 |
285
Rep 2,146
Drives: F80 M3
The only reason I haven't done a tune is due to my extended warranty although I am thinking of doing that open tablet flash
07-20-2013, 07:15 PM | #10 |
285
Rep 2,146
Drives: F80 M3
Will do thanks for the advice!
