Exclamation Point Warning?
07-18-2013, 05:21 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Does anyone know what this is? It only comes on when I put the car in "start"... Once I physically start the car, the exclamation point disappears.
http://tinypic.com/view.php?pic=2wp55ki&s=5
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-18-2013, 05:23 PM | #2 | |
17
Rep 473
335i Space Grey Coupe/ppk/ssk/pe exhaust/perf susp
07-18-2013, 05:26 PM | #3 |
335i Owner
56
Rep 839
I don't have either... I have an 07 335i but, this came on after coding some modules on my car with Wedge last night. We coded a few things with the Key Fobb and a few other things... should I just reset back and go code by code?
07-18-2013, 05:37 PM | #4 |
17
Rep 473
yea that would probably be the easiest. as its not the car on the lift symbol at least its not major.
07-18-2013, 05:57 PM | #5 |
1048
Rep 5,660
use the lever in the middle of the blinker stalk thing to cycle through until you see "Check Control." Then press the button on the end of the stalk. It'll tell you what's wrong.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-18-2013, 06:28 PM | #6 | |
681
Rep 3,696
07-18-2013, 06:32 PM | #7 |
335i Owner
56
Rep 839
I have the car on lift symbol too
07-18-2013, 06:35 PM | #8 | |
335i Owner
56
Rep 839
Someone else mentioned the car with ramps was caused by coding that in with an outdated version of SP Daten. I have the updated version of SP Daten but still got this error code. I'm going to try and remove later and pray this fixes it. I had TMPS yesterday before I coded everything, ran my tune and everything was fine. Coded last night, turned on this morning and TMPS was on and so was the car with ramps. I reset TMPS and it is working fine now... The car with ramps is still on... Edit: Thank you so much Fazman! I got a CC ID 60 which a Speedometer Error (I was right, this module is causing the issue for me).. I will try changing it later unless someone can help me with NCS Expert?
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms Last edited by JDrago1926; 07-18-2013 at 06:40 PM.. |
07-18-2013, 06:37 PM | #9 | |
1048
Rep 5,660
Cheers,
07-18-2013, 06:40 PM | #10 | |
1048
Rep 5,660
Cheers,
07-18-2013, 06:43 PM | #11 |
335i Owner
56
Rep 839
Was that supposed to be funny? Just wondering...?
07-18-2013, 06:46 PM | #12 |
1048
Rep 5,660
Yes, it was. I do know your "ramps" aren't the veggie I pictured, but I don't know what you actually meant by saying the car "has ramps." I figured you didn't mean you have the car sitting on a ramp.
Cheers,
07-18-2013, 06:49 PM | #13 | |
335i Owner
56
Rep 839
http://www.e90post.com/forums/attach...1&d=1344716603
07-18-2013, 06:50 PM | #14 | |
1048
Rep 5,660
FWIW, I always thought of that as a lift, not a ramp. Thus my confusion.
Cheers,
07-18-2013, 06:55 PM | #15 | |
335i Owner
56
Rep 839
It can be for service but, in my case I have a CC ID 60 which is a speedometer malfunction (digital speedometer isn't working)... I'm hoping when I make this deactivated later or if anyone can help me both exclamation and car with lift/ramps go away... then my car will be "perfect"
07-18-2013, 07:12 PM | #16 | |
681
Rep 3,696
07-18-2013, 10:09 PM | #17 |
335i Owner
56
Rep 839
I was able to remove the digital speedometer and remove the car with lift. No more service codes woot!
07-18-2013, 10:13 PM | #19 |
335i Owner
56
Rep 839
Indeed, the exclamation point warning was the car door open with the iginition, how stupid of me!
07-18-2013, 10:15 PM | #20 |
17
Rep 473
congrats you saved yourself a painful trip to the dealer! not that you would take it there anyway..
07-18-2013, 10:17 PM | #21 |
17
Rep 473
i'd love to see the expression of the SA if you had dropped your car off and if they would try to charge to diagnose
07-18-2013, 10:18 PM | #22 |
681
Rep 3,696
