Another frackin brake warning light...
07-18-2013, 04:58 PM | #1 |
Came to the N55 Darkside
1112
Rep 12,740
Is it common for the N55 to have all these brake sensor issues? I mean it's fixed and it's no big deal, but this is the second time this happened within 6 months
07-18-2013, 06:34 PM | #2 | |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-18-2013, 06:44 PM | #3 |
1048
Rep 5,660
With normal driving, I'd say no, it's not so common. But how you drive has a lot to do with it. You should still be in your warranty period, so were I you, and I drove about like most folks do, I'd just head on over to the BMW dealer.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-18-2013, 06:53 PM | #4 |
1112
Rep 12,740
Yeah they say there's issues with the rear brake sensor... I don't drive like a track rat, but I'm not exactly a conservative granny driver.
07-18-2013, 07:00 PM | #5 |
681
Rep 3,696
07-18-2013, 07:10 PM | #6 | |
1112
Rep 12,740
07-18-2013, 11:17 PM | #8 | |
681
Rep 3,696
I think my front/rear pad count is still at 1 and I'm @ 66k miles (I'm a firm believer in braking being a waste of gas ) |
07-19-2013, 04:57 AM | #10 |
1112
Rep 12,740
Then how will you know when there is an issue brother?
Anything having to do with issues with the braking and accelerating system concerns the shit out of me, quite frankly. |
07-19-2013, 05:39 AM | #11 |
62
Rep 944
Something is shorting the sensor. When the pads is suffienctly worn the sensors would short against the rotor. Since there's 8mm of pad left - it's still thick enough.
Either the sensors are are installed properly or something is shorting it elsewhere - get a new brake pad sensor. |
07-19-2013, 07:47 AM | #12 | |
1112
Rep 12,740
07-19-2013, 10:01 AM | #13 |
26
Rep 606
Mankind went over 100 years without brake pad sensors.
Just change the pads at the regularly scheduled intervals or when they start squealing like crazy. The sensors are flimsy and pointless. |
07-19-2013, 10:29 AM | #14 |
1112
Rep 12,740
This is true. However, I am not all all car savvy and would appreciate the convenience of using the warning systems as they were designed on the car - since I paid for them anyway
07-19-2013, 10:31 AM | #15 |
69
Rep 1,766
Ah, the 'ol brake pad sensor issue. Had one come up on me a couple of months ago, stealership said nothing's wrong, had it come up again as soon as I left the damn service station and they finally did some voodoo magic to make it disappear for good. German engineering at its best...
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
07-19-2013, 11:34 AM | #16 |
26
Rep 606
I guess if they're free and covered under warranty and you don't mind going to the dealership to get them changed periodically. Nah, even then I'd still disable the buggers.
07-19-2013, 12:55 PM | #17 | |
681
Rep 3,696
All brake Pads have a fail safe which is they make loud grindy noises when they are low. If you happen to ignore that... you can still drive all the way to the point where you have no brakes and the car will just constantly keep the brakes ON 100% of the time so you are basically fighting the brakes to get movement. So for you to be able to say in modern cars 1980+ that you didn't know you needed new brakes is a little far fetched |
07-19-2013, 01:10 PM | #18 |
317
Rep 905
07-19-2013, 01:33 PM | #20 |
317
Rep 905
07-19-2013, 01:50 PM | #21 |
1112
Rep 12,740
