Warning Light
07-18-2013, 02:02 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Warning Light
Added my digital speedometer and my clock isn't set anymore.. now I have the middle warning light with the car on ramps... any idea? BTW that isn't my car, just the middle light is the issue I'm having.
http://www.e90post.com/forums/attach...1&d=1344716603
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-18-2013, 02:13 PM | #3 |
335i Owner
56
Rep 839
I'm going to try that now but, any ideas?
07-18-2013, 03:04 PM | #5 |
164
Rep 401
It's normal for the clock to require resetting depending on which module you are coding. As for the warning with the car on ramps, did you try resetting it? On occasion I have had service items pop up earlier than expected after making various changes, but resetting the service intervals solved the issue. Easy fix. You didn't specify if you tried resetting it and it refused to go away or if it simply popped up and you haven't tried to do anything about it yet.
I also second what Red Bean said, looks like the brake pads symbol, though it is odd that it is coming on red if it never came on yellow first. |
07-18-2013, 03:10 PM | #6 | |
335i Owner
56
Rep 839
07-18-2013, 03:12 PM | #7 |
60
Rep 1,024
By "added my digital speedometer" do you mean coding? If so, this is a common problem. You need to download the latest Daten files and reupload them to the car. When recoding the Kombi module (where the digital speedo is enabled) this happens often. It happened to me the first time I coded my car too.
07-18-2013, 03:22 PM | #8 | |
335i Owner
56
Rep 839
I cleared my TMPS code by resetting through the toggle... I still have windshield washer fluid (this car sucks that down especially with all the bird crap in NY) and I still have the car on ramps.
07-18-2013, 03:23 PM | #9 | |
335i Owner
56
Rep 839
Edit: I was using the most updated SP Daten
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms Last edited by JDrago1926; 07-18-2013 at 04:04 PM.. |
07-18-2013, 10:10 PM | #10 |
335i Owner
56
Rep 839
Read the BMW manual and this turned out to just be the car door open with ignition ON
