Huge Pothole - Now Headlight is Pointing Sky High - Help! E92 335i
07-18-2013, 12:45 PM | #1 |
318
Rep 1,410
Drives: X3 M40i
I hit a badass pothole last night and then noticed later that night that my drivers headlight was pointing sky high. When I got back home to my garage I shined the lights on the wall and noticed the drivers was indeed way higher. I found the manual headlight adjustment level and used a screw driver to try and adjust it, unfortunately it won’t adjust in either direction, tried screwing it both ways a number of times. The passenger side manual level screw works fine and adjusts up and down.
Does this mean my whole headlight would need replaced or just the level mechanism? My insurance covers pothole damage on the collision part of the plan ($1,000 deductible). Wondering if I did go through insurance if I could have them pay new wheels and tires though... I think all of my wheels are bent slightly. The pothole was massive and may have scratched just under the front lip too. Car is driving fine otherwise though, just the headlight is pointed too high. Really don’t want to spend a ton of money here, but looks like it’s going to cost me at least something. Wonder if my insurance rates would go up if I made a claim… Any thoughts you guys have would be great. Do you know where I could find a cheap used 2007 335i e92 xenon headlight? What would install cost? |
07-18-2013, 01:07 PM | #3 |
1048
Rep 5,660
Only way to know for sure how best to proceed is to visit the dealership and find out what they'll charge. Then you can shop around to find out if someone else can do it correctly and for less money.
All the best and hope the situation resolves to your satisfaction. EDIT: FWIW, Xenon lights, if they must be replaced can be expected to run around $1K give or take.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-18-2013, 01:23 PM | #4 |
65
Rep 554
Drives: E92 335i 6MT
Are you comfortable with removing the front bumper and removing your headlight assembly? If so, you can take it out and try to get the servo back on track. There are some instructions floating around for E90 xenons.
07-18-2013, 01:43 PM | #5 |
318
Rep 1,410
Drives: X3 M40i
I probably wont try to remove the bumper and diagnose it myself... too busy, not enough tools, etc..
07-18-2013, 01:44 PM | #6 |
Zeed
17
Rep 561
It can be done as long as nothing is broken, I did it. You will need to take off the back cover of the headlight like you would do so to change xenon bulb, remove the xenon bulb and force the bracket up or down for servo motor arm to pop back in. Search forum for DIY for this issue.
http://www.e90post.com/forums/showthread.php?t=41184 |
07-18-2013, 03:37 PM | #7 |
318
Rep 1,410
Drives: X3 M40i
anyone in the NYC area that would want to help me out with trying to fix? definitely could compensate you for your time
07-18-2013, 04:27 PM | #9 |
19
Rep 564
I have a set of E92 headlights for sale. $600+ shipping. lol
07 AW E92 335 6MT [18" OEM 193's For Sale, PM me] OEM Aero Lip | OEM Gloss Black Kidney Grills | KW V2 | Vorsteiner CSL trunk | M-Tech Rear Bumper | LCI Rear Taillights | Angel ibright Angel Eyes | 3000K HID fogs | 6000k HID low beams | AFE DCI | Full LED conversion |
07-19-2013, 01:21 PM | #11 |
681
Rep 3,696
Yea its the servo's that popped off from the hard hit. If your under CPO... I think they will cover that (just don't tell them you hit a pot hole). If your auto insurance covers the damage, than you might always want to take that route. Those headlights new are about $1500 each i believe. You will also need to fix the Bent/cracked rim, bubbles/damaged tires, wheel alignment, inspection time for looking for other damaged parts, etc...
07-19-2013, 08:28 PM | #14 |
Rep 22
Popping the servo arm back into place can be done from the wheel well area by jacking up the car and removing the wheel and wheel well liner. The bumper and headlight don't have to be removed. But in this case I'd go to the dealer first and see what they say.
07-20-2013, 08:10 PM | #15 |
318
Rep 1,410
Drives: X3 M40i
thank god I'm friends with the guys at the bmw dealer, they said normally they would just replace the headlight, but instead they will try to fix it for me, and just charge for a couple hours of labor.... bringing it in on wednesday for the appointment.... The guy also reserved me an F10 5 Series as a loaner car for the day, sweet!
07-25-2013, 09:21 AM | #16 |
318
Rep 1,410
Drives: X3 M40i
couple hours of labor ended up being a grand total of $481 after tax... at least they fixed it without me having to buy a brand new headlight assembly
