07-18-2013, 09:36 AM | #1 |
13
Rep 34
320i Tune Suggestion
Hi all,
Looking at getting a 320i XDrive... Want to "de-neuter" the 2L turbo engine... I see Berger has a JB4 that seems to work with the 320i's engine... Any other suggestions? Any comments on what sort of HP/TQ increases the 320i sees with the current JB4 maps? |
07-18-2013, 11:12 AM | #2 | |
Rep 61
07-26-2013, 05:20 PM | #4 |
Rep 25
Hi guys from Russia! My bmw f30 320i have been cracked by our craftsmen, city Yekaterinburg. They filled my ECU with 328i program ! Watch this ))
My 320i stock After the upload: And start with 328i stock, camera inside my car |
08-01-2013, 08:30 AM | #8 |
Rep 61
english translation: the software for I drive was changed...anyone can do it that knows are cars.
its impossible to load the 328 fuel parameters into the 320i without blowing the engine . the 320i has a different compression ratio. that small shop is full of you know what. 320i- 11:1 328- 10:1 |
08-01-2013, 02:43 PM | #9 | |
Rep 25
I don't know the details, can only say ECU has been opened and transferred to the recording mode someway then filled the adjusted program 328i through OBD-connector (first 50 (fifty) kilometers ECU already in recording mode) I know about compression ratio, but despite it all works fine Now there is a problem only with intercooler overheats, so i need to somehow set intercooler from 335 - ams or forge |
08-01-2013, 02:47 PM | #10 | |
Rep 25
DME unit has been modified, not i-drive that is already not impossible, my engine still works fine |
08-02-2013, 01:17 AM | #13 | |
Rep 25
But not true, I watched them throughout the procedure moreover there were some races with two stock 328i, сars accelerates equally up to 180 km/h One guy in Saint Petersburg set BMS stage 2 + downpipe, now his 320i has 260hp at 5th mode, and 280hp at 2nd mode. Both of modes are faster then 328i stock |
08-02-2013, 07:39 AM | #16 | |
42
Rep 186
And a modded 328i with stage 2 is supposed to hit that in 4.9s A 320 is not just a detuned 328... |
08-02-2013, 10:25 AM | #17 | |
Rep 25
http://www.bmw.de/de/neufahrzeuge/3e...che-daten.html There is 5.9s 0-100 One guy in Moscow did 4.7s on 328xi fbo stage2, i am not sure i could do the same time with my RWD, but will see i know that difference 320i & 328i in the exhaust system and pistons (also reducer) My car works well, that's why i can say the difference in the pistons is not a big deal, except that it is more prone to detonation. And it does not matter if use our 98 petrol (sort of yours 93) |
08-15-2013, 06:23 PM | #18 | ||
Rep 66
08-21-2013, 12:05 AM | #21 |
Rep 61
I dont understand how your intercooler could be overheating if its adequate for the 328. they are the same part number... I think you have something else going on causing this heat issue... cylinder heads is my best guess. I think your really pushing your engine to its limits if this info your providing to us is accurate. your engine is probably running fine under normal driving conditions but under wot, your probably getting heat issues due to the tune. your gonna burn out your plugs soon. Have you tried hotter plugs?
08-21-2013, 06:48 PM | #22 |
450
Rep 992
