Bad Battery cause bad WP?
07-18-2013, 08:38 AM | #1 |
Rep 194
Unfortunately, I also became a victim of car overheating Had barely gotten on the freeway and I soon as I turned on the A/C, hot air was coming out and then I received the yellow then red message. Now, not too long ago I received a letter from my BMW dealer about a recall regarding my battery terminals being replaced. My battery also has had low charges, not common but I get them here and there on start up. My clock either gets reseted to 00:00 or if I leave the ignition on for about 2 min or so I receive a warning on battery being low.
Car gets driven at least 40 miles a day and I always thought it recharges fine (stupid me I know ). Been seeing a couple threads about battery being a potential cause for the water pump not turning on. Im going to scan it using the BT tool to see if I receive any additional codes later on today. I havent checked the engine bay for spilled coolant yet, seems like thats a common thing to happen on bad water pumps. 09 335i, has 62k miles running on the original water pump. My question is can a bad battery be the cause of it? I know, I know, im expecting it to be the water pump on top of it but one can hope right?
2009 BMW 335i Jet Black - BMS Dual Cones, GP Thunder 7500k Fog's, Hellst XRT H8 AE, JB4 G5 ISO Map 5 -
2001 Cobra True Blue - Terminator Swap, 460WHP - |
07-18-2013, 08:42 AM | #2 |
118
Rep 1,933
I doubt your battery is the culprit for this matter. Get your waterpump done, and take your car in for the recall. Ultimately you will need to change your battery as well since it seems like it is pretty weak.
You are lucky your car heated up as you pulled in your driveway haha! |
07-18-2013, 09:07 AM | #3 | |
Rep 194
Very anxious to see if it spilled or leaked any coolant as it had gotten a low coolant light before about 6 months ago. Wont find out till I get home from work
07-18-2013, 09:19 AM | #4 | |
118
Rep 1,933
07-18-2013, 10:20 AM | #5 |
Rep 194
Thanks man! Don't know too many indy shops besides Babarian Workshop which I heard mixed reviews about, might do it on my own. One very weird thing also, I never saw my oil temps rise at all, they were perfectly normal. Is it supposed to be that way?
07-18-2013, 11:28 AM | #6 | |
118
Rep 1,933
Have you gotten the red sign saying that your car is over heating? or just yellow saying that the car is running warmer than its supposed to? Maybe try topping off the coolant and driving before changing the pump? As far as indy shops go, maybe posting in your regional forum will being you some luck |
07-18-2013, 12:14 PM | #7 | |
Rep 194
07-18-2013, 12:26 PM | #8 | |
118
Rep 1,933
is your heat blow cold? |
07-18-2013, 01:24 PM | #10 | |
Rep 194
Didn't try the heat. I turned off the car as soon as I could.
Im checking out the codes, coolants, and any leaks as soon as I get home. I really hope its not the pump but all signs lead to it.
07-18-2013, 01:47 PM | #11 | |
118
Rep 1,933
