Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Brake discs size bigger than E46 M3
      12-04-2005, 03:11 AM   #1
Xens
Eh
Xens's Avatar
108
Drives: Is Turbo'd
2006 330i  [0.00]
13.0F/13.2R for E90 vs. 12.8F/12.9R for E46 M3.
It's not much, but I guess it's something to feel good about.
Sorry, forgot to mention it's for 330, 325 is a bit smaller.
      12-04-2005, 03:19 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
Normal M3 ( euro )
Front: 325x28
Rear: 328x20
M3 CS
Front: 345x28
Rear: 328x20
E90 330i
Front: 330x24
Rear: 336x22
M3 still has thicker front discs and more aggressive pads. Euro version of M3 also has floating discs
One also has to look at the pad surface area. I think the M3 may have more
      12-04-2005, 03:21 AM   #3
Xens
Eh
Xens's Avatar
108
Drives: Is Turbo'd
2006 330i  [0.00]
Originally Posted by E90Fleet
Normal M3 ( euro )
Front: 325x28
Rear: 328x20
M3 CS
Front: 345x28
Rear: 328x20
E90 330i
Front: 330x24
Rear: 336x22
Good info, I was just lurking bmwusa.com, heh.
What's floating disc btw?
      12-04-2005, 03:40 AM   #4
E90Fleet
South Africa
1312
Drives: BMW
The piece of the brake that the pad touches and the pice that is attached to the cars hub arnt of one piece of mettal and are connected via special "floating" hubs.
So as heat goes into the brake the one part can expand indipendantly from the other. And you can make each from the optimum type of metal for its work.
      12-04-2005, 03:41 AM   #5
E90Fleet
South Africa
1312
Drives: BMW
From Brembo
Why use a two-piece "floating" disc assembly?
There are several reasons that a two-piece floating disc assembly is of benefit. First, by using an aluminum bell for the hub section of the disc saves a great deal of weight. Since this is both rotating and unsprung, it benefits the acceleration, braking, and handling of the vehicle. Secondly, it is better able to handle the large temperature changes that a brake disc experiences. During severe use, temperature variances become present in a one-piece disc and generally cause warping of the disc. This not only results in vibration of the vehicle, and pulsing of the brake pedal, but also pushes the pistons farther away from the disc. In a two-piece floating disc assembly, the iron disc heats up more uniformly, and the controlled float which is present allows for the differential expansion of the very hot brake disc, and the relatively cool aluminum bell. This allows the disc to be used under severe conditions without having a detrimental effect.
      12-04-2005, 03:55 AM   #6
SRT
United Kingdom
8
Drives: BMW 5 Series
E46 M3s' brakes are cross-drilled, no?
      12-04-2005, 10:45 AM   #7
ward
155
Drives: F
OK, but does it stop better??
      12-04-2005, 11:27 AM   #8
ryan330
Drives: 330 soon
I believe the M3 takes about 2.6seconds to get from 100km/h to 0, and the 330 takes about 2.9s, so in short the M3 brakes are better
      12-04-2005, 11:43 AM   #9
Xens
Eh
Xens's Avatar
108
Drives: Is Turbo'd
2006 330i  [0.00]
Yeah, doubt it stops better, just found it surprising that we have bigger discs.
      12-04-2005, 12:18 PM   #10
CMD
Guest
n/a
Drives:
Yes, if it has the competition package.
      12-04-2005, 12:29 PM   #11
E90Fleet
South Africa
1312
Drives: BMW
All euro ones are aswell
      12-04-2005, 12:46 PM   #12
BMW0
BMW0's Avatar
Drives: AW E90 330i
2006 330i  [0.00]
Yea! Bigger brakes than M3
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive"
      12-04-2005, 12:56 PM   #13
Atty
Atty's Avatar
16
Drives: 09 X5 48i M-Sport
Anybody ever use ceramics? Since all of these cars stop short enough for me, the benefit would be no brake dust. Just wondering.
BTW - I always think about the problem caused by superior brakes: the '87 Cutlass Ciera Brougham driven by an uninsured dope - and she's on your tail. I spend more time looking through my rear view mirror than anything else under hard braking....seen too many rear-enders. Anybody else feel this way?
Attorney
E90 330i 6MT | Black Sapphire | Terra | Burl | ZSP | ZPP | ZCW | Navi | Sirius
      12-04-2005, 04:28 PM   #14
visor
BMW, can I have some LSD please?
visor's Avatar
88
Drives: 2017 F30 340i xDrive
Ceramic brakes are crazy expensive. Porsche has an option for the 911.
Only problem is they're also quite fragile... make sure you don't wash your car/wheels or drive thru any puddles of water immediately after you get them nice and hot with massive braking, or else cracks = expensive repair.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired
2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired
2017 340i xDrive | Estoril | Black | Al | 8AT | M Package
cdti12.50
      12-04-2005, 04:53 PM   #15
ward
155
Drives: F
it's also an option on Boxster, Cayman
I find it very hard to belive that Porsche would put out "fragile" brakes on a production car
also the poster above was probably talking about ceramic compound pads, not rotors, probably another brake dust complainer
      12-04-2005, 06:05 PM   #16
M3NTAL Kev
Drives: 1991 318is
The brake size might have to do with the vehicle weight when compared to the e46 M3.
      12-04-2005, 08:54 PM   #17
Robert
417
Drives: 135i -> is350 -> Tesla M3 perf
Thought the main benefit of ceramic is resistance to fade during high strain usage of the brakes. I dont track my car so I never feel my brakes fade except one ocassion when I was younger. Going down Lake Arrowhead Mtn at 10pm with no cars on the road and I was attacking the road at decent speed. 3/4 way down the mountain I felt my brakes aren't as responsive anymore. I was young and didn't know "brake fade." until I pulled over at a gas station below the foothills and smelled my pads burning.
      12-04-2005, 09:49 PM   #18
xdrive
20
Drives: 330xi
Anyone know why the rear brakes are larger than the front brakes? With all other cars, the front brakes are usually larger...
      12-04-2005, 09:55 PM   #19
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
My guess is that...most other cars....
the front weigh a lot more; therefore, bigger brakes in front.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      12-04-2005, 10:19 PM   #20
visor
visor's Avatar
88
even for a 50/50 wt distribution, they should be the same size
my guess is because the rear brakes now are used more in the e90 due to dsc+, ie. hill hold, dtc, electronic brake diff (simulated limited slip) and also due to greater power to the wheels.
      12-04-2005, 11:41 PM   #21
ward
155
Drives: F
you're both pretty much incorrect on the sizing issue
the fronts are larger because as you brake the weight transfers forward enabling the fronts to use more brake force (front gets heavy rears get light as you brake) than the rears.
the rear disks on our cars have the parking brake drum built into the center hub, plus I'd assume the crazy DSC features require having larger brakes than the car would otherwise need.
Also I'm pretty sure the car senses how you're stopping and trys to brake more with the rears when it's safe to help even out pad wear from front to back (people with older auto tranny cars should remember replacing fronts 2-3 times before needing to replace the rears)
the fronts should be bigger
      12-05-2005, 12:02 AM   #22
visor
visor's Avatar
88
1. first you start off by saying the fronts are larger, then you end up saying the fronts should be bigger. so which is it?
2. for the e46 (and most cars that I can think of offhand), the fronts are bigger than the rears, while this is reversed for the e90. we're trying to understand/postulate why the BMW engineers did this for the e90. we know that under heavy braking the wt transfers to the front causing more braking forces needed for the front brakes, but why then did BMW go larger rear brakes than the fronts?
