Faulty Injector?
07-17-2013, 11:00 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Faulty Injector?
View post on imgur.com How many plugs would you say here have faulty injectors? I'm told the one all the way to the right looks like a faulty injector and wanna make sure... If so, where can I order an OEM injector for a good price? It's going to cost me $200 to get it coded and swapped by MNC Performance.. Thanks! Also, will I notice a difference after the injector is swapped (car not throwing code)
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-18-2013, 10:30 AM | #2 |
Rep 113
Drives: 2007 BMW E90 335i
If I had to guess it would be the furthest on the right. Did they smell like gasoline? I just had all 6 injectors replaced and before all my plugs looked black and reaked of gas. Check in the for sale section for a injector the dealer will be alot more expensive.
07-18-2013, 10:55 AM | #3 |
319
Rep 1,023
Of note, if your injectors are still original, you can't just replace one with a new part. BMW issued a new "improved" part that is incompatible with the old one, so if you replace one, you have to replace all 6. And they're $100 more than the outgoing part. Eh.
On a side note, I do have a few USED old part number injectors sitting around for when I have more issues. I may be persuaded to part with one if you're interested.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
07-18-2013, 11:02 AM | #4 | |
335i Owner
56
Rep 839
I don't wanna put all the money into new injectors right now, I'd rather just purchase an old one and upgrade all 6 when I can.... How much do 6 new injectors run for? Can I get away with just swapping cylinder 6's injector? I have no problems or codes currently starting.
07-18-2013, 11:22 AM | #5 | |
319
Rep 1,023
IIRC, a new injector is around $240, each, and you have to buy ALL 6. And get them coded just like the old ones. However, hopefully you can find someone in your area to do it for free. I picked up the cable for $100, and after a few hours of setup I coded my own. Twice now (got my money's worth!). PM me if you're interested in a used one and we can work something out.
07-18-2013, 11:37 AM | #6 | |
335i Owner
56
Rep 839
Sent you a PM.
07-18-2013, 01:32 PM | #7 |
Zeed
17
Rep 561
There was a new bulletin issued by BMW that you can now install injectors by banks if replacing with the new ones as long as each bank has the same type injectors in it. So the most you will have to by are three injectors of the new type.
07-18-2013, 10:11 PM | #8 |
335i Owner
56
Rep 839
Thanks that sounds awesome!
07-18-2013, 10:16 PM | #9 |
681
Rep 3,696
This is true, my car had the injector recall done in summer of 2011, they swapped out 3 injectors on bank one (bank two is all original still).
07-18-2013, 11:01 PM | #10 |
58
Rep 494
Wasn't there a recall for injectors? Could not find it here on E90post, but it is here http://www.n54tech.com/forums/showthread.php?t=10933 .
07-18-2013, 11:04 PM | #11 | |
335i Owner
56
Rep 839
07-18-2013, 11:14 PM | #12 |
58
Rep 494
Yeah,that might not work then. Not sure if these are correct, but injectors at 94.99 or 116.79 seems low on price.
http://www.rockauto.com/catalog/rafr...rttype=6224&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=t4q7bbeigst61o0ug1qd4oqaq5 |
07-18-2013, 11:17 PM | #13 | |
335i Owner
56
Rep 839
