JB4 Misfiring
07-17-2013, 06:50 PM | #1 |
Rep 17
JB4 Misfiring
I've just installed the JB4 and was excited, put in on map one, and went wot hit 4000rpm and misfired. Turned off the car restarted and it went away, put it on map 0 WOT and ran fine. Emailed terry and sent pics and everything was is in correctly. So tomorrow I'm changing all my plugs considering I bought it used I have no idea when they were last changed an I'm at 83k. So hopefully this foxes it, it was misfiring on multiple cylinders. The plugs seem like a good idea?
Thanks for responses. -XHGWX- |
07-17-2013, 07:46 PM | #2 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
read your codes to be sure.
Plugs, and check coil packs, |
07-17-2013, 07:58 PM | #3 |
60
Rep 1,024
Step one is spark plugs for sure. That was the culprit when I had this issue. I'd also suggest walnut blasting to help clean out all the junk that accumulates inside the engine. Other possible causes include coil packs and injectors.
