07-17-2013, 04:17 PM | #2 | |
Knight Commander
554
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
07-17-2013, 04:38 PM | #3 |
10
Rep 67
I have done it. It's trivial. Trickiest part is getting the center overhead light off. But there's a guide somewhere on the internet for taking apart the F10 for lights.
07-21-2013, 02:19 PM | #5 |
Rep 51
It's quiet easy... do a search on LED interior lights in this forum and look at my post, as well as some others. I bought the EAS F10 kit, as well as a trimming kit from EAS.
* 2021 BMW X7 M50i * 2016 BMW F10 M5 Pure Metal Silver Limited Edition * 2008 Lexus GX470 * 2000 Acura NSX-T |
07-22-2013, 10:28 AM | #7 |
10
Rep 67
07-22-2013, 10:33 AM | #8 |
10
Rep 67
07-22-2013, 10:55 AM | #9 |
Internet Crash Test Dummy
331
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
The BMW info on how to remove the dome light is attached.
Simply remove the plastic trim (outer ring) and use a small screw driver to pop off the entire assembly. All other bulbs can be easily replaced by just using a small screw driver and pop out the lights. If you had the doors open for a while the bulbs will be HOT , so be careful when touching them
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
07-30-2013, 12:02 PM | #12 | |
Rep 51
Here you go: http://f10.m5post.com/forums/showthread.php?t=779077 I've been very pleased with the ECS Tuning LED light kit.
08-07-2013, 05:52 AM | #13 |
53
Rep 563
I swapped to LEDs. It really updates the look of the interior. IMHO the car should have come from the factory this way. It's an easy DIY. As others have posted, use the info provided on the forum.
08-07-2013, 12:10 PM | #14 |
13
Rep 236
08-10-2013, 12:11 PM | #15 |
7
Rep 102
I replaced every bulb except for the front doom. The instructions are for the 5 series but not M5. I just could not remove the clear plastic piece/lense. Are there any better tips how to remove that plastic piece?
03-07-2014, 06:24 AM | #16 |
210
Rep 715
Hi Guys,
Just came across this old thread. I just took delivery of a '14 650 coupe and want to do the interior LED upgrade. Curious about one thing, the factory BMW 10 LED accessory has 2 different types of bulbs, 6 of the "wedge" and 4 of the "flat" type. Where are the flat type used? I know the doors/footwell/dome/glovebox are wedge. Don't see where the other type is used Thanks |
03-07-2014, 09:15 AM | #17 |
57
Rep 451
There is a great guide with all the parts required here:
http://bd8ba3c866c8cbc330ab-7b26c6f3..._LED_Light.pdf |
03-07-2014, 10:41 AM | #18 |
210
Rep 715
Thanks - my 6 series (F13) should be basically the same except for no rear dome and only 2 doors. Curious is there any difference between the 9 chip wedge used for the puddle and the 5 chip used for the footwell/dome? Connector is the same.
06-09-2015, 11:57 PM | #19 |
Rep 7
Beware!
So I got the EAS kit, and I got the trunk, and the door ones taken care of and then started the hardest part, which was the dome lights in the overhead console - Got the part out and all that, and even though the car was switched off, ended up shorting something while changing the bulbs leading to a 4 digit repair cost and a replacement head unit being shipped from Germany. Safe to say having learned the hard way, paid $300 including labor and got BMW to replace them all with the OEM LED kit. Now i'm stuck with an EAS kit that I need to get rid off! Keep in mind, i've changed LED interiors on BMWs and other cars successfully before, I just think the M5 is a little different. In hindsight, maybe disconnect the battery...
06-15-2015, 09:26 AM | #20 | |
Hide! My wife's coming!
808
Rep 2,816
