XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Vendors Classifieds
      07-16-2013, 10:07 AM   #1
GMP Performance
GMP Performance's Avatar
Drives: E90 M3, E82 135i, E90 325i
Bimmerfest East Active Autowerke Software Sale from GMP Performance
It's not easy waiting for an awesome event like Bimmerfest. So Active Autowerke is here to help make that time go by a little quicker with a special pre-Bimmerfest East Software Sale!
Their software for the X6M is not only discounted but as an added bonus, you get a FREE Simon handheld programmer. Considering the Simon programmers are $350 each and the massive savings from the software, you're looking at almost $500 off!
ECU Upgrade for the BMW X6M
BMW first, an M SUV. The BMW X5M & X6M have quickly grown to be a favorite among BMW enthusiasts looking for a new thrill. The new 4.4L Twin Turbo Engine Boast an amazing 555 HP from the factory. Our engineers have spent countless hours in R&D and are now producing an additional 86 Rear Wheel Horsepower. and an additional 117 ft lbs of peak torque (when compared to factory). Our software upgrades includes a complete remap of the DME which adjust the part throttle maps, wideopen maps, ignition maps, and fuel tables to produce this increase in horsepower and torque. All factory safety parameters have been left in place resulting in reliable everyday performance. This upgrade is a must for the enthusiast looking to take advantage of their X5M/X6M's true potential.
Key Features:
Increase of 86 Rear Wheel HP and 117 Ft lbs of Peak torque
Higher torque over factory settings throught RPM range
Recalibrated settings for a smoother and more responsive part throttle transition
Recalibrated settings for a smoother and more responsive power delivery
Ability to tune all DME's
Tune available for 91 or 93 octane fue.
Tune also available for Euro Spec & Other International Octane Ratings
The SIMON Hand Held Programmer
Conventional software tuning requires the BMW ECU to be shipped to the BMW tuner like Active Autowerke where its modified/uploaded at their facility by their software engineers. Once upgraded, your ECU is then reshipped back to you via Fedex with a minimum downtime. The ECU is then re-installed back into your BMW and then made ready for your driving pleasure. Total down time is minimum three days.
With the SIMON hand held programmer, you become the one uploading the performance software into your own BMW. All that is required is the ownership of the SIMON hand held programmer, a laptop and access to the internet for use of e-mail correspondence.
The SIMON tool will communicate and read the ECU data within your BMW. You then upload this stock data file from thte SIMON tool to your laptop and later submit via e-mail to Active Autowerke your stock ECU data. Once received by Active Autowerke, the performance reflash/upload is created and resent back to you via e-mail. All of this can be accomplished within the same day.
The steps to follow are relatively easy just like following SIMON in counting 1-2-3.
Best of all, there is no down time with your BMW. By reading the stock ECU data through the OBD11 diagnostic port, you are only making a copy of the existing ECU data so your BMW remains intact and can still be driven normally. The benefits are great considering your reside on another continent with a different time zone. Add the possibility of having the package become lost or damage while in transit and the down time of three days or more versus a one day upload when done by yourself.
The SIMON stores both stock and performance files on your personal laptop. This is extremely beneficial if the need arises to revert back to a stock, factory setting. If you are a racer, the SIMON has the capability to store multiple software filese like a ** race gas tune ** as well.
If you are spirited driver that wants to switch between pump 93 octane and E85 ethanol, then the SIMON has the ability to store alternate software files for you to upload and switch at will.
If you are a drag racer and wish to switch to 110+ race octane, then the SIMON tool has the ability to store alternate software files for you to upload and switch at will.
If you are a circuit racer, you select differential gearing to suit the course. What if you needed a higher RPM limit between shifts, then the SIMON has the ability to store alternate software files for you to upload and switch at will.
The range of applications are only limited to your imaginations. The Active Autowerke SIMON tool makes possibilities become reality.
Advantages:
Simple, easy installation
Backed with Full Tech support
ECU data is only read, making your BMW downtime non-existent
Software read and upload performed by BMW owner
Software read/upload can be performed within the same day
Eliminate the possibility of a damage or lost to the BMW ECU during freight
Ability to revert back to factory settings anytime
Ability to have multiple software files for uploading
Disadvantages:
Additional cost involved
Non-transferrable, married to specific BMW when activated
All this good stuff and for a heck of a deal. How can you pass it up?
For more information, click here!
Trey @ GMP Performance
Phone: 704-525-0941 x 254
Email: trey@gmpperformance.com
Website: www.gmpperformance.com
Tags
active autowerke, bimmerfest east, gmp performance, sale, software
xbimmers
