HELP! .. Oil in rear Turbo
07-15-2013, 11:18 PM | #1 |
217
Rep 1,909
I took out downpipes and was surprized the rear turbo downpipe FILLED with oil, I have a puddle on the ground ... oxygen sensor's black vs front's white ... I took pics, can someone pls advise where its coming from ?
From the pics it seems as if its entering from wastegate, the whole area from under WG to turbine is wet with oil ... Here are some pics, HELP Downpipes - rear turbo's filled with oil Downpipes again Oil puddle from rear DP, front downpipe Dry O2 Sensor also black for Rear Front Turbo - Normal Last edited by 007_e350; 07-15-2013 at 11:29 PM.. |
07-15-2013, 11:24 PM | #2 |
217
Rep 1,909
Here's the turbo with puddle of oil in DPs, oil traces show coming from WG...
The picture is inverted vertically, WG is on top, oil flowing down to turbine due to gravity |
07-15-2013, 11:29 PM | #3 |
General Nuisance
25
Rep 277
I had a similar situation, are you on upgraded or stock turbos?
'07 E92 335i 6MT
Full Bolt On's, Vargas Stage 2's, Carbon Fiber, and Methanol. |
07-15-2013, 11:39 PM | #5 |
217
Rep 1,909
Stock everything ... Just installed JB4 two weeks ago, I bought the car 4k miles ago though
No warranty Rear turbo inlet pipe kept coming off, investigation required DP removal which lead to this "treasure" |
07-15-2013, 11:51 PM | #6 |
General Nuisance
25
Rep 277
Did you have a heavy bluish smoke? Any smoke? My guess would be your turbo was weak and worn out to begin with due to oil contamination or hard use and the turbo seals are on their way out. he JB4 probably helped expose the weakness in the system and oil is now making its way into places it shouldnt. I would attempt to look into the PCV system failing, try purchasing a vargas or RB PCV valve. If there is excessive crank case pressure, it would force oil into the turbos. That is a relatively cheap fix, so I'd try this first before immediately jumping to new turbos. If that doesn't fix it, your turbos are on their way out. They will work, but you will have high oil consumption and oil contamination.
Honestly, that doesn't look too bad but I can see the oil eventually contaminating the cats. My guess is it's probably not the PCV due to the fact that it's only on one side. If it were high crankcase pressures it would probably be forcing oil past the seals on both turbos. I'd recommend TRYING the PCV valve since it helps oiling issues for relatively little investment and seeing if it improves; if not it seems like new turbos or rebuilt turbos are in your future. Checklist of things to check in order: - Verify oil pressure / levels. If too low, probably due to excessive oil consumption. If too high, probably due to overfilling. -Modify PCV and remove any low-quality catch cans. -Look into turbo rebuild or replacement. VTT offers some good durability upgrades for a similar or cheaper price than new OEM. If you're on a budget you can take chances with used parts from a low mile car. Best of luck, sorry to bring about bad news. I'm not an ASE mechanic but these were my experiences with a similar oiling issue.
'07 E92 335i 6MT
07-15-2013, 11:55 PM | #7 |
217
Rep 1,909
Is it possible the WG on rear turbo doesn't close all the way causing boost air with oil entering into the turbo ... ? the front turbo WG seems to be little less open than rear in the pics if u observe
anyway, aren't turbos under warranty to 82k ? |
07-16-2013, 02:38 AM | #8 |
General Nuisance
25
Rep 277
Turbos are warranteed for waste gate rattle. If you bug them enough it might work but honestly it looks like a blown turbo seal to me, particularly since it's isolated to one turbo and seems to be coming from the exhaust turbine and not the just the waste gate. How many miles on your car / what psi were you running?
Now might be a good time to look into a pair of RBs or VTTs for more longevity. The car will need turbos regardless of if it's waste gate or turbo seal. Hopefully you can get BMW to warranty it. Just delete the tuner codes and annoy them enough about the waste gate rattle if you have it.
'07 E92 335i 6MT
Full Bolt On's, Vargas Stage 2's, Carbon Fiber, and Methanol. Last edited by Snaggletooth; 07-16-2013 at 02:43 AM.. |
07-16-2013, 11:13 AM | #10 |
814
Rep 3,953
Time for turbos. The seal is done. The cats will mask a leaking turbo for a long time.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
07-16-2013, 11:31 AM | #11 |
13
Rep 185
I'd say it's time for new turbos. Every time we have a car in the shop with oil in the rear turbo it's usually on the way out. If you're lucky you may still be within warranty, otherwise it might be a good time to upgrade.
07-16-2013, 12:25 PM | #12 |
195
Rep 6,136
07-16-2013, 01:48 PM | #13 |
General Nuisance
25
Rep 277
^ What he said. This is why I went for upgraded turbos. It could be a blessing in disguise, especially if you anticipate running higher power levels.
'07 E92 335i 6MT
07-17-2013, 12:41 AM | #15 |
39
Rep 315
07-17-2013, 04:51 PM | #16 |
217
Rep 1,909
I'm thinking abt ordering turbo rebuild kit, I htink the piston (bearing) would be shot thats the only seal in the core)
http://shop.midwestturboconnection.c...s-1401-404.htm Last edited by 007_e350; 07-17-2013 at 06:31 PM.. |
08-22-2013, 06:24 AM | #17 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Any update?
08-22-2013, 10:35 AM | #18 |
217
Rep 1,909
well I put everything back and boost is upto 14 psi which is live-able for now - I'm shopping for chargha / used turbo and will swap when I find a good one, what issues are you having ?
08-22-2013, 11:04 AM | #19 |
456
Rep 6,478
I still need to pull off the downpipes to verify 100%, but I’m basically in the same boat as you. At least one turbo bank is punished turbo seal wise, though as others have said it still will boost perfectly, just a lot of obnoxious smoke and some oil consumption. The consumption has fallen since switching to 5-40W, but the smoking has not. Def. not coolant, never had a low coolant warning ever and the smell is 100% oil and gas.
Saving up for Stg2 offerings, hopefully we can get some real deal VTT STG2 numbers in the next month or so.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-22-2013, 11:41 AM | #20 | |
217
Rep 1,909
08-22-2013, 11:46 AM | #21 |
239
Rep 3,708
Drives: E90 335i Modded
How many miles do you have? I believe our turbos were covered up to 80k even after the factory 50k expired. Could be wrong but I had mine replaced right before I hit 80k by the dealer.
08-22-2013, 11:53 AM | #22 | |
456
Rep 6,478
I think the extension covers for excessive WG rattle and shaft play, never heard of someone getting new turbos bc the seals were pushing through and burning oil. And I don't even have most of my stock parts anymore, there's no way the dealer is going to do that type of warranty work on my car as-is
